I recently got by Beolab 5000 system assembled and thought that all was well. All the scratching noises are gone when making any adjustments, all lights are working, but I keep gettig a scary loud "pop" when the power is turned on. Volume is off and even if I start up with the speaker switch off, once the switch is pushed to on, there is a loud one time pop that I am afraid will one day damage the Beovox 5000's. There seems to be a lot written on this on many web sights mainly concerning "vintage equipment" but not to many answers.
Is there something that needs to be cleaned, would I be able to see some arching if I opened the unit.
Worst case before going into expensive repairs, is there some sort of inline relay that could be installed between the speakers and the amplifier. It seems to me that that's what my Beomaster 7000 is doing, as when it is first turned on or power applied, there is a delay and then you here a relay switching.
Thanks anyone for your help.
Andrew
