Latest post 12-06-2010 1:58 PM by Steve at Sounds Heavenly. 3 replies.
Page 1 of 1 (4 items)
  • 12-06-2010 8:30 AM
    Link solution with more than 2 units
    Today I have a BeoCenter2 and a BeoVision10 connected with a regular Masterlink cable between them. I´m now thinking about buying an extra pair of speakers to use in another room.  What do I need to make this work, i.e. how do I split the ML-cable into two? Thanks in advance for your help!
  • 12-06-2010 9:35 AM In reply to
    Re: Link solution with more than 2 units
    B&O make a splitter box - small plastic product. You will need a Beolink active for the other room to allow full control.
  • 12-06-2010 10:59 AM In reply to
    Doctor:
    Thanx! I have looked "everywhere" for some info about the slitter (price, specifications etc) and I cant find any. Anyone have a link to share?
    Another question: If I connect another TV, e.g. a BeoVision 6, through the splitter box, in another room, can I use it as a speeker and use the remote whithout having a Beolink active and eye?
  • 12-06-2010 1:58 PM In reply to
    Hi Stefann,
    You can also use a Masterlink Junction Box, which allows you to cut the cables and join them easily for a permanent connection.  These come with a fitting tool and full instructions.  Let me know if you need any help in finding one of these.
    You can use a BeoVision TV as a speaker in a link room without a Beolink active and eye - simply link this to your main room products via Masterlink and select the main room source from the link room.
    Kind regards,
    Steve.
    Sounds Heavenly Cables are proud to be a sponsor of the BeoWorld Forum!
