I'm really in need of some help here, here is the story:
I changed some components on my Penta II (only one of my pair for now..) with the idea of giving them many more years of health.
Last intervention on my working Penta (which was already modified/restored: capacitors of the main power supply, opamp, and signal path capacitors) was yesterday, changes (only worked on the amp card) listed here:
-changed the opamp IC2 to opa 2134 after having tried a linear chip I didn't like so much
-changed some old capacitors for new ones (C27, C29, C31)
-changed some more capacitors (the ones around the +-15v regulators, C18,19,20,21 and 22)
Then I got tried to measure and adjust the idle current as I usualy do before reassembling everything and.... no idle current at all !!!
All the logic and control worls at it should though, red without signal, green as soon as signal is applied, standby timer, all ok.
Of course I checked everything again few times, polarity of the new capacitors, solder, loose cables, etc..
Couldn't find anything, so I spent hours (I'm definitely functioning beyond my technical knowledge, so I'm slow and puzzled..) measuring with voltmeter and oscillo, the opamp part is 100% ok, so are both power supply, so my guess is that the problem lies in the part of circuitry which is full of discrete transistors (and which I didn't touch appart from 2 capacitors, of course I may have unvolontarily fried something?)... alas this is not easy for me to troubleshoot, I do understand the basics of a transistor, but no chance here.
As much as I can tell it seems the transistors do not activate. (except maybe T8? I measured 1.9v Base-Emitter)
Let me insert this aera of the circuit here (from service manual..), I added on it 2 things I found, for one I can't probe with voltmeter or oscillo along the line underlined in pink as it sends the amp in overload mode (blocked with orange light).
Second I noticed the signal gets amplified and looks clean till a certain point (C25, or T3, proof that the opamp part is ok), beyond that lots of noise, higher frequencies, are added. (the 68v supply is clean originaly)
Edit: I commented wrongly the schematics, the point indicated (just before C25 or T3) is where the high freq noise already appears. before R27 things look clean.
I thought T3 might be responsible somehow, so I removed it completely and that didn't change anything...
I hope someone here will have the knowledge to help me troubleshot this or give me some hint about the right methodology to use in order to find the origin of the trouble.
Thanks in advance!
