Latest post 12-04-2010 11:39 AM by joeyboygolf. 3 replies.
Page 1 of 1 (4 items)
  • 12-04-2010 9:00 AM
    BS3000 CD Mechanism - Type
    Hi - my friend whose an engineer has had a look at my BS3000 and it needs a new mechnism - B&O have quoted £200 for the parts - does anyone know if I can use one from another CD player like a philips? or is it propriety? It's the large clamp one with N.Music etc.
    Any help as always much appreciated.
    Beovision Avant 32 RF, DVD1, Beovision 1, MX4002, Beound 3000, Beolab Penta MKII, Beovox Penta, Beolit 707, Beolink Passive, Beovox C30, Beocom 4, Beogram TX, 4 x Beo4, Form 1 & 2, Beocenter 7700, Beovox S65,
  • 12-04-2010 9:53 AM In reply to
    Re: BS3000 CD Mechanism - Type
    It's proprietary I'm afraid so you can't rob one from another make although plenty of competitors do use the same basic mechanism.
    The B&O kit will include the later CD Pro II and a new interface board.
    In all probability, you do not actually need a new mechanisn. It is probably the familiar C2103 type of problem that occurs with all the other Philips CD servo boards and would cost pence to put right!
    I am not familiar with the servo board used in the Beosound 3000 types but someone out there must be. Suggest you try Dillen or Die_Bogener.
    Regards Graham
  • 12-04-2010 10:37 AM In reply to
    Thanks Graham - is c2103 a capacitor - not sure what you mean by that problem, but I'm sure the guy whose looking at will - could you explain a bit more please. Many thanks in advance
  • 12-04-2010 11:39 AM In reply to
    Just put c2103 in the search box and search the whole site. Yes, it is a capacitor used to smooth the laser supply in Beocenter 9000/9500 types.
    The same circuit is not used in the Ouverture and it's derivatives but I believe  there is similar.
    I have just checked the service manual and I could be talking complete bo11ocks. I suggest you contact Dillen or Die_Bogener who will certainly know more than me!
    Regards Graham
