Latest post 12-05-2010 8:10 AM by BjarkeP. 2 replies.
Page 1 of 1 (3 items)
  • 12-02-2010 2:48 PM
    Beovision 6 MBP through DVI
    Hi guys...
    I desperately need help on connecting my MacBook Pro to my Beovision 6.
    I've conncected everything as dictated by the manual, however it doesn't seem to work.
    My Mac has identified the extra display as BeoVision 6, but when I press list on my remote, I cannot choose PC and get the picture on the tv?..
    Help is so much appreciated :)
    Best regards - BJARKE
  • 12-03-2010 10:01 AM In reply to
    • Seven
    • Not Ranked
    • Joined on 11-22-2008
    • Posts 35
    Re: Beovision 6 MBP through DVI
    You need to add "PC" to the list.
    Steps:
    • press power+list simulateously
    • display on the remote control shows "add?"
    • press go
    • press list until you see "pc" in the display
    • press go. display will show "added"
    You can also reorder stuff inside list. Check out the manual!
  • 12-05-2010 8:10 AM In reply to
    Hi Seven,
    Thank you so much - your help was appreciated :)
