Latest post 04-18-2007 4:34 PM by Craig. 5 replies.
Page 1 of 1 (6 items)
  • 04-16-2007 4:53 PM
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Beocenter 4000 (Type1603) Question
    On a Beocenter 4000. Older type with single cassette. How do you change between LW an MW? Do you press the tuning dial?
    CraigBig Smile
  • 04-16-2007 5:56 PM In reply to
    Re: Beocenter 4000 (Type1603) Question
    Yes - the same as the Beomaster 2200.
  • 04-16-2007 6:49 PM In reply to
    • Dillen
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Press on the large flush dial wheel, you'll notice that only the dial in use is lit.
  • 04-17-2007 5:45 PM In reply to
    • Craig
    • Posts 4,855
    Just as I suspected, the switch no longer works. Thanks for the replies Peter and Martin.
    CraigBig Smile
  • 04-18-2007 1:06 AM In reply to
    • Dillen
    • Posts 5,008
    It's probably not put together correctly. When mounting the frontpanel you need to observe the switch arm and make sure that it grips correctly.
  • 04-18-2007 4:34 PM In reply to
    • Craig
    • Posts 4,855
    It has had the volume control seen to in the past. From what the last owner tells me.
    CraigBig Smile
