Latest post 11-30-2010 6:47 PM by ........... 2 replies.
Page 1 of 1 (3 items)
  • 11-30-2010 4:59 PM
    • fishta
    • Not Ranked
    • Joined on 02-12-2009
    • London
    • Posts 79
    Effects of recessing BeoLab 7
    I just wondered whether anyone had any experience of recessing a BeoLab 7.1/2/6?
    I know it has the downward firing subwoofers but the plan is to recess into a wall which has been built in and then we cut holes for the subwoofers so they fire the bass into the mdf boxing.
    I know it is not the ideal solution for acousitcs but it should look awesome so I just wondered if anyone could share any experiences??
    Cheers
    BeoVision 7-40 MkV
  • 11-30-2010 6:36 PM In reply to
    Re: Effects of recessing BeoLab 7
    I think it will sound terrible...
  • 11-30-2010 6:47 PM In reply to
    I know someone who has a 7-40 and 7.2 flush mounted (it's actually on a pull and rotate STB bracket for service access in specially created cut out in a wall - There is no acoustic trickery, the ports just fire straight down onto the flat surface...
    Looks great, sounds super. I think the bass is slightly enhanced by this actually.
    There is approx 10mm clearance around the edges of the speaker!
    Hope this helps.
