Great to see Beoworlders helping eachother !
Please note that Beogram turntable datalink cables are different from Beocord tapedeck cables.
The Beocord cable is two-way (record and playback).
The Beogram cable is one-way (only playback) but has double shielding.
The cables are not interchangeable though you can play back from a Beocord using a
Beogram cable (but you cannot record) and you will get a serious hum if using a Beocord
cable with a Beogram.
