Latest post 11-29-2010 12:43 PM by Dillen. 2 replies.
Page 1 of 1 (3 items)
  • 11-29-2010 11:35 AM
    What type of speakers in a Beomaster 1200 RG?
    Smile
    I've started to restore the RG 1200 that I picked up a couple of months ago.  I  notice that there is some "scratchyness" in the treble on one side.  It's kind of distorted...more so with louder settings, less so during soft passages.
    My question would be, before I start taking things apart, What kind of speakers are used in this console?  Does anyone know how to get into them?
    Guy
  • 11-29-2010 12:39 PM In reply to
    Re: What type of speakers in a Beomaster 1200 RG?
    On my 900 Compact you lever the grills off from the front (carefully!!) and then you can access the speakers.
  • 11-29-2010 12:43 PM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    It has an oval woofer (SEAS 28/17 TV) and two tweeters (Peerless MT20HFC) each side.
    Maybe one of the tweeters are bad.
    Or the filter capacitor.
    The speaker panels come out from the front, 2 screws from below each side, I think.
    The panels are held in grooves at the top, work carefully so you don't damage the veneer.
