Latest post 02-15-2011 8:05 AM by Heribert. 5 replies.
Page 1 of 1 (6 items)
  • 11-28-2010 3:39 AM
    switch off DVB-T Module in BV8-32 Servicemenue??
    I have a BV8-32 and added the Systemmodule with DVB-T just yesterday. At the time of installation the module was not available.
    Connected to the BV8 is a Technisat DVB-S2 Receiver via Scart and HDMI on AV1. This was controlled via PUC and as DTV. Now with the new module the DTV is used by the DVB-T module that I do not need. The Receiver can just be controlled as V.AUX - very inconvenient!!
    Is there a way to switch off the DVB-T Module? Can this perhaps be done in Service menue? How to enter service menue??
    Thanks, Heribert
    BeoVision 8-40 / BeoVision 8-32 / Beovision 6-26 / BeoSound 3200 / BeoSound 1 / BeoLab 3 /  Beolab 6000 / Beolab 2000 / Beoport / Beomedia 1 / 3* Beo4 /BeoCom 5 with VOIP
  • 11-28-2010 8:04 AM In reply to
    • LC
    • Not Ranked
    • Joined on 11-23-2010
    • London
    • Posts 24
    • Silver Member
    Re: switch off DVB-T Module in BV8-32 Servicemenue??
    in a short answer, no you cannot switch it off.
    The only way you can get the DTV button usuable again is to remove the module.
  • 11-28-2010 11:40 AM In reply to
    Any other ideas? Can I connect it as V.MEM? I tried but could not add a STB Control...
    Is the BV8-32 so different from my main room BV8-40?
  • 12-02-2010 12:23 PM In reply to
    • LC
    • Not Ranked
    • London
    • Posts 24
    • Silver Member
    i think but dont quote me on this. if u update the tv sw it might let u use v.mem for control..
  • 12-02-2010 1:01 PM In reply to
    • Vienna
    • Top 100 Contributor
    • Joined on 08-15-2008
    • make an educated guess
    • Posts 712
    Heribert:
    Any other ideas?
    Yes, if you don't need DVB-T, just ML and SCART:
    Use system module Type 4375 (without DVB-T - PartNr 1437500) instead of your current Type 4470 module.
    Both types have the same price.
    Sometimes less is more ...
  • 02-15-2011 8:05 AM In reply to
    The solution was quite simple.
    1) It is not possible to switch it off on BV8-32
    2) My dealer exchanged the BEO4 to a version with V.Aux as hard key. Instead of TV + DTV it has DTV + V.Aux...
    Thanks,
    Heribert
