Latest post 11-29-2010 11:30 PM by leogenghis. 5 replies.
Page 1 of 1 (6 items)
  • 11-26-2010 3:22 PM
    2 x HDMI Sources on Beovision 8 32
    Hi All
    Has anyone come up with an integrated way to get 2 x HDMI sources into the the single HDMI socket on the BV8?
    I presume the HDMI expander is not supported on this model?
    Warren
  • 11-29-2010 2:31 PM In reply to
    Re: 2 x HDMI Sources on Beovision 8 32
    I take it from the lack of replie nobody has come up with a solution for this?
  • 11-29-2010 3:26 PM In reply to
    A HDMI-switch should do the job.
  • 11-29-2010 4:02 PM In reply to
    That's true... However I would lose the ability to use the puc to control both sources if the bv8 is unaware of the switch
  • 11-29-2010 6:18 PM In reply to
    That's also true, but I think there is no other solution, a HDMI expander is not supported by BV 8-32.
  • 11-29-2010 11:30 PM In reply to
    Unfortunately that's a downside of the BV 8-32. I use an HDMI switcher and have to use 2 remotes. However, if one of your sources has component video output you could use that and program the PUC to use only one remote, but you probably already thought of that.
    Leo
    BV 10-40, BV 8-32, BL 9, BL 4, CX100, BS Ouverture, BS 2000, BG 4500, Passive, LC 1, A 9
