Latest post 11-28-2010 7:06 PM by Dave. 12 replies.
Page 1 of 1 (13 items)
  • 11-26-2010 1:15 PM
    Beo4 with built in light
    I have had an idea for a wile, and today i tryed building it.
    4 small LED's in the beo4 display, to se "LIST" in the dark.
    I still have some other tests to doo... Like less bright LED's maybe only 50mcd like on the left insted of 160mcd on the right.
    The On and Off is controled by a small tilt-switch.
    I will follow up, as the progress goes by.
    Here is a video so far: http://m.youtube.com/index?desktop_uri=%2F&gl=US#/watch?xl=xl_blazer&v=kGni5NIeNt0
  • 11-26-2010 2:10 PM In reply to
    Re: Beo4 with built in light
    Well done so far. Looks like it is off and running. Keep us posted as you progress!
    • B&o bottle opener
  • 11-26-2010 3:08 PM In reply to
    • Seanie_230
    • Top 75 Contributor
    • Joined on 04-20-2007
    • Milton Keynes, England
    • Posts 962
    • Gold Member
    Looking good so far. If I could still get a beo4 cinema I would as this would be perfect for my cinema setup
    This very well may be the next best thing
    Keep us posted
    Beovision 7 MKIV (Blu Ray)
    Beolab 9
    Beolab 6000
    Beo 4
    Beocenter 9300
    Apple TV
    SKY HD
    Optoma HD65 Projector
    Lintronic TT455-RT-238
    Beovision 3 MKII
  • 11-26-2010 4:14 PM In reply to
    Or you could get this and save the effort!
    http://www.engadget.com/2010/11/23/pop-up-microlite-turns-your-janky-remote-into-a-well-lit-even-j/
    3 for under $20 - wohoo and it really will enhance the look of that boring Beo4 Whistle
    Stoobie
  • 11-27-2010 3:00 AM In reply to
    Yuck!Ick!
    Reunion Island is greeting you!
  • 11-27-2010 8:10 AM In reply to
    • TWG
    • Joined on 04-17-2007
    • Germany
    • Posts 950
    • Gold Member
    Schmedegaard:
    Very nice! Would you mind sharing the instructions how you made and installed it into the Beo 4?
    Due to the tilt-switch: Does the LED stay on when you put the remote into the wall bracket?
    I think want to modify my Beo 4, too :)
  • 11-27-2010 8:23 AM In reply to
    • Step1
    • Joined on 07-06-2008
    • Manchester
    • Posts 961
    • Gold Member
    Here I am wishing I had a Beo4 to modify :) BTW You video is not in the link...
    Olly.
  • 11-27-2010 8:37 AM In reply to
    • Seanie_230
    • Posts 962
    • Gold Member
    Well i Vote as customers we should start a petition for B&o to bring back the Beo4 Cinema and make it a product we can buy and replace when needed.
    I for one would order Two striaght away. Not all of us like the Beo5/6 but the beo4 i still love
    Come on boys and girls lets tell them what we want....
    Beolab 9
    Beolab 6000
    Beo 4
    Beocenter 9300
    Apple TV
    SKY HD
    Beovision 3 MKII
  • 11-27-2010 9:05 AM In reply to
    I am sure they were about £500 each for a beo4 cinema!!
  • 11-27-2010 9:43 AM In reply to
    • Seanie_230
    • Posts 962
    • Gold Member
    ok well lets bash them into making it again but the same price as the current beo4 ;)
    Beolab 9
    Beolab 6000
    Beo 4
    Beocenter 9300
    Apple TV
    SKY HD
    Beovision 3 MKII
  • 11-27-2010 12:24 PM In reply to
    Seanie_230:
    I agree! I would buy one, then!
  • 11-28-2010 6:53 AM In reply to
    Hi all
    After disassemple, i removed the foil on the back of the display, to get a better light reflektion.
    I made a pice of polycarbonate(plastic) 1mm thick. Paintet it white on the backside, and made 4 square cuts, 2 on eagh side.
    Glued in the 4 LED's (0402) and connectet them in 2 parralel connections, with a 330ohm resistor on the positive side. Then soldared the tilt switch to the ground on the pcb(print circuit bord), and the positive to batteri.(4,5 volt)
    And it will always turn on when liftet/tiltet up, so it would'nt shut off when mounted in the wallmount. But this could be solved with a ritz-relay (magnetic relay) so when placet in the wallmount it shuts off. Or you could built in a ic555 time relay, så it shuts off after a predefined time.
    Unfortunately i did'nt take pictures under the construktion, as i was to focust on getting it done:-)
    i will defenently work on it in the next couple of weeks, and then take some pictures:-)
    More questions, feel free to ask.
    Sorry If the spelling is wrong... Hope you get it anyways.:-)
    Schmedegaard
    Denmark
  • 11-28-2010 7:06 PM In reply to
    • Dave
    • Top 50 Contributor
    • Brisbane, Australia
    • Posts 2,328
    That is brilliant!! Well done, you are very clever!!!!
