Latest post 11-26-2010 3:00 AM by classic. 3 replies.
Page 1 of 1 (4 items)
  • 11-24-2010 6:00 PM
    Is SP7 ok?
    I have found a website that is selling a sp7.  Currently on the turntable is a sp14.  Can I just buy the stylus sp7 and stick it in the "can" of the sp14?
    Thanks!
    Guy
  • 11-25-2010 1:48 AM In reply to
    Re: Is SP7 ok?
    Yes. However the cartridge body is very slightly different. They do fit though - as indeed will the SP10 and 12 styluses.
  • 11-25-2010 6:33 PM In reply to
    Re: Is SP7 ok?
    Smile
    Thanks...I went ahead and ordered the stylus.
    Guy
  • 11-26-2010 3:00 AM In reply to
    • classic
    • Top 500 Contributor
    • Joined on 04-16-2007
    • Venø - Struer / Denmark
    • Posts 224
    Re: Is SP7 ok?
    I suggest you re-calibrate your B&O tonearm.
    The SP6/7 and SP10 - SP12 - SP 14 are two different "groups" of weight, that means the adjustment of your tonearm must be calibrated.
    /Frede
    Beolab 5000 -  "If another amplifier sounds different then it needs repair!"
    Filed under:
