chartz:
Tell us, did you replace or clean the two speed adjustable resistors? A bad contact at the cursor could generate that sort of thing.
Replace or clean those R1 and R2 adjustable resistors. Do you have any skills (like building kits) in electronics?
Also a noisy motor usually is more obvious when turning without its belt... So my guess is an electronic fault but then the deck is at your place!
Hi Chartz,
I haven't replaced anything as yet, no time for now, but thanks for the advice..always accepted, never rejacted..
Yes I cleaned and checked all the adjustable resistors some time ago, the problem still persists.
And yes I have Electronic skils, 22 Years in the Royal Air Force as an Electronics Engineer on Radar, Boimedical Electronics and the like, so have plenty of experience, Just at the time didn't have recourse to a CCT Diagram (which I now have thanks to this very site), so was just looking for a "short cut" if you get my drift. I also always go for mechanical issues with any electronics as most of the time the issues are usually the mechanical parts thereof. Also from my experience with the 4000 and other such B&O equipment I am aware of the overall good design and general reliebality of their kit.
Now I have the CCT diagram I will 'scope the Motor supply over the weekend to see if all is ok, as an aside I have quite heavy DC on the mains here and had to trim the Motor supply for my 4000 (ac motor) to get it to run quietly.
Will update with scope shots, and general piccies as I progress.
Steve F
