Latest post 11-26-2010 9:42 AM by hagan. 3 replies.
Page 1 of 1 (4 items)
  • 11-24-2010 2:19 PM
    Beolab 3500 + Beomaster 7000, no clock in display
    Hi!
    Just connected a Beolab 3500 to Beomaster in a link setup. At first 3500 showed time from beomaster. After adjusting time on beomaster the clock disappeared from Beolab 3500. I used MCP 5500 when adjusting time. Can this be the reason?
    Edit: added setup:
    Bm7000 - Converter - ML - Beovision 10 - Beolab 3500
    s/w 1.1
  • 11-24-2010 6:02 PM In reply to
    • Opman
    • Top 200 Contributor
    • Joined on 12-31-2007
    • Cheshire, UK
    • Posts 323
    Re: Beolab 3500 + Beomaster 7000, no clock in display
    It may be a software issue with the BeoVision10. Usually you set the clock on the video master, in this case it isn't possible with the BeoVision10.
    Remove the Masterlink from the BeoVision10 - option programme the BeoMaster7000 to option 1. Then set the clock as before. Once you have the time displayed on the BeoLab3500, revert back to your current Masterlink set up.
    Then next summer do it all again. Whistle
  • 11-25-2010 2:42 AM In reply to
    Hi!
    I disconnected Bv10 and restarted everything. No difference. I noticed, when I connected everything the first time yesterday that it took a short while before the clock appeared in Bl3500 but as earlier mentioned, after resetting time with MCP 5500 it disappeared. I have used Beolink 5000 before when I did all timer settings but it`s broken. Can it be why it´s not working? Are they (bl5000) avaliable new as a complete spare part
  • 11-26-2010 9:42 AM In reply to
    Anyone got any more ideas?
