I have just bought a Beomaster 2000 which seems to work ok but the left hand hinge is broken. Is it still possible to obtain replacement hinges from anywhere? Thanks.
Unfortunately not. B&O threw away all the trim items for this era of product some years ago. Your choices are limited to finding a donor unit or repairing what you have. Someone may have a donor unit on site.
Thank you for reply. I`ll keep a look out. Regards.
