Latest post 01-31-2011 6:51 AM by Glen fizzawizz. 15 replies.
Page 1 of 1 (16 items)
  • 11-21-2010 1:44 PM
    • stotty1111
    • Top 75 Contributor
    • Joined on 12-16-2007
    • UK / France - Nth Worcestershire/Finistere
    • Posts 924
    • Gold Member
    Beolink 1000
    Me ma's BL1000 has given up the ghost, checked /changed the batteries, checked voltage out of battery area and into the pcb and across the capacitor, checked terminals connecting wires board to battery area etc all ok, anything else to look for - it apparently just stopped working - kaput or what?
    salut
    tony(now in uk and it does seem cold here)!
    I always try to operate using/following the KISS principle --  Keep it simple stupid!
  • 11-21-2010 2:09 PM In reply to
    Re: Beolink 1000
    Is there any dirt under the contact foil? Water, salt, dirt, CocaCola, beer...
    It's possible, that the BL1000 thinks, there is a button activated all the time.
  • 11-21-2010 2:13 PM In reply to
    Re: Beolink 1000
    Die_Bogener:
    Just what I was going to say. I had the same problem with A Beolink 1000 a few years back. Cleaned it and it has worked perfectly ever since.
  • 11-21-2010 2:52 PM In reply to
    • stotty1111
    • Posts 924
    • Gold Member
    Re: Beolink 1000
    Tried that still no joy - tried pressing all buttons - all seem ok
    more?
    t
  • 11-21-2010 3:29 PM In reply to
    • kallasr
    • Joined on 04-19-2007
    • Willich, NRW, Germany
    • Posts 1,077
    Re: Beolink 1000
    Did your ma get a plasma tv set recently.... Those disturb the reception for b&o signals.
    Had this issue trying to control an Beocenter AV5 that was close to our plasma TV.
    Ralf
    My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD,  Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
  • 11-21-2010 4:08 PM In reply to
    • stotty1111
    • Posts 924
    • Gold Member
    Re: Beolink 1000
    no just used to control an Ouverture and an MX5500 ty
    t
  • 11-21-2010 4:21 PM In reply to
    Re: Beolink 1000
    It reminds me of getting my Beovison LX5500 from an auction some years ago.
    The Beolink 1000 did not work but I could turn the LX on by the buttons.
    I went straight ahead down to the nearest B&O shop and got the print replaced.
    The LX and Beolink 1000 still works to this day.
  • 11-21-2010 6:03 PM In reply to
    • Vienna
    • Top 100 Contributor
    • Joined on 08-15-2008
    • make an educated guess
    • Posts 712
    Re: Beolink 1000
    stotty1111:
    ... it apparently just stopped working - kaput or what?
    ... very likely!
    Tony, replacing the main-pcb (OrderNo 8007900) and, if it's a pre MKIII BeoLink 1000 ´
    (STEP <> instead of arrow UP/DOWN to change program/title)  also the set of buttons
    (OrderNo 2776010)  should be the solution  ...
  • 11-21-2010 7:01 PM In reply to
    • MartinM
    • Not Ranked
    • Joined on 08-07-2008
    • New Zealand
    • Posts 49
    Re: Beolink 1000
    If you use a digital camera or camera on a cell phone pointed to the IR end of the Beolink you should see the LED's flashing. At least that will indicate if there is a "stuck" button or any life at all when a button is pressed.
    Have you tested the two capacitors inside?
  • 11-22-2010 1:55 PM In reply to
    Re: Beolink 1000
    Here is a posting I put on the Yahoo Beolist sometime back and the solution. Please read the postings from the bottom one up!
    Hope it works for you.
    Re: Broken Beolink 1000
    WOW success!! - it worked brilliantly. Thank you so much, that was
    great. To think, I had forgotten about Beolist and haven't been on
    here for months.
    Thank you
    Stoobie
    --- In
    beolist@yahoogroups.com, "Frank" <frank.ttt@p...> wrote:
    > Try this:
    > Get out the batteries and short-circuit the + and – contact of
    the
    > battery holder in the BL1000. Put the batteries back in and try
    > again. Some Duracell batteries have very small positive contact
    > tips. They give bad contact and cause the microprocessor to crash.
    > Success
    > --- In beolist@yahoogroups.com, "stoobie_too" <sbs@g...> wrote:
    > > Last week my Beolink 1000 was working perfectly. It stopped
    > working
    > > one night and I assumed the batteries were running low. I
    replaced
    > > them with new Duracell but it still does not work. I am the only
    > one
    > > at home so it has not been dropped or damaged. I was using it to
    > > teach my new Pronto Remote all the B&O codes.
    > > Have I pressed a button combination that has stopped it working?
    > > I spoke to my local dealer who says they do not repair Beolink
    > 1000
    > > but only do a trade for a refurbished one. At £95 it is quite a
    > > lot. (I have just had my Beolink 5000 repaired at a cost of
    £150
    > > so I do not need the extra expense, but find remotes in all the
    > > rooms helpful)
    > > Any "Techies" out there who can suggest a solution?
    > > Thanx
  • 11-25-2010 9:19 AM In reply to
    • stotty1111
    • Posts 924
    • Gold Member
    Re: Beolink 1000
    Stoobie
    BRILLIANT!!!!!!!!!!!Big Smile
    Wonderful tip - yes it worked for me - had tried the digicamera to id operation of led's alas nothing but now i have a huge cheesy grin and a working bl1000
    again thanks for the tip!
    salut
    tony
  • 11-26-2010 8:58 AM In reply to
    • eddglynn
    • Not Ranked
    • Joined on 04-16-2007
    • London SE1
    • Posts 11
    Re: Beolink 1000
    Worked for me too! I just couldn't figure out what was wrong with mine, but shorting out the battery contacts brought it back to life. Handy trick with the phone camera too. Big Smile
    Edward Glynn London
  • 11-26-2010 12:13 PM In reply to
    • BenSA
    • Durban, South Africa
    • Posts 808
    • Gold Member
    Re: Beolink 1000
    That is so clever and quite amazing...would never have thought!
    Durban South Africa
  • 11-26-2010 3:20 PM In reply to
    Re: Beolink 1000
    Unfortunately I can't take the credit, but such a simple trick!! Just glad to be able to pass it on to help Big Smile
    Stoobie
  • 11-27-2010 2:25 PM In reply to
    • stotty1111
    • Posts 924
    • Gold Member
    Re: Beolink 1000
    Forgot to add in earlier post thanks to all for suggestions etc - still have cheesy grin after the successful fiddling!
    t
  • 01-31-2011 6:51 AM In reply to
    Re: Beolink 1000
    I too thought my beolink was kaput last night. Sad Then after searching through the threads and finding stoobies advice on short circuiting, voila!! all is well again.
    Thanks chaps,keep up the good work.
    PS specail thanks to stoobie Yes -  thumbs up
