I'm back after a few months. System is great to have, but I noticed that the turntable is in fact running slow. It seems to speed up after about 10 minutes but is still a bit on th slow side even though the speed is at Max.
I did remove the back of the turntable but did not really see anything that I could easily access. Everything looks new and I can't see any "old" grease.
Do I have to take off the back of the Motor, and if I do will anything fall out?The back of the motor has a few screws that are quite tight. Will something happen to the alignment if I loosen these.
Any help would be apreciated.
Andrew
