Hi all B&O gurus,
I'm still trying to figure out how to connect the Beocentre 2 to my new Beosystem 3. Both units are in the same room, and I like to watch DVDs on the BC2 through the BS3 so I can get 5.1 surround.
I've tried connecting using a Masterlink cable, and setting V.OPT (BS3) to 2 and A.OPT (BC2) to 0. Then I can control the BC2 via AV-DVD but unfortunately then it means I get the sound and not the video, as I've read somewhere the ML only transmit sound and not video.
If I plug a SCART cable onto one of the AV ports on BS3 to get a video signal, then how does it work with the ML cable? I can assign the AV port as DVD but then pressing AV-DVD and pressing DVD on the remote are different. If I connect a SCART and Digital COAX into one AV port, how do I set it up so that the BS3 can control the BC2 (and what V.OPT and A.OPT settings should I use?)
Anybody please advice how I should go about in setting this up? Thank you so much in advance!!
Beomud
