Latest post 12-02-2010 7:55 AM by Spiros. 11 replies.
Page 1 of 1 (12 items)
  • 11-17-2010 10:57 AM
    Beolink PC Office
    Does anyone on this forum use Beolink PC Office? This is not Beolink PC 2 or Beoport.
    I would like to learn more about the unit's capapbilities and limitations, and what software is available to support it.
    Thanks!
  • 11-17-2010 11:17 AM In reply to
    Re: Beolink PC Office
    The main difference is the it uses a serial port to connect with the PC rather than a USB socket.
  • 11-17-2010 12:05 PM In reply to
    More specifically, does anyone have a recent or the latest version of Beoplayer working with the Beolink Office PC?
  • 11-29-2010 3:10 PM In reply to
    Wow. I can't believe no one on this forum uses a Beolink PC Office device. Could someone with this device respond here?
  • 11-29-2010 3:26 PM In reply to
    • Spiros
    • Top 50 Contributor
    • Joined on 09-03-2007
    • Thessaloniki GREECE
    • Posts 1,088
    • Gold Member
    Indeed it's very old gear and I'm pretty much sure that it is not used anymore by anyone.
    But maybe we can help if you let us know the issue
    Best regards
    Spiros
  • 11-29-2010 4:41 PM In reply to
    Has anyone been able to use a recent version of Beoplayer with Beolink PC Office?
    Does Beolink PC Office work with a PC running Windows XP or Windows 7?
    Thanks in advance,
    John
  • 11-29-2010 5:29 PM In reply to
    • Spiros
    • Posts 1,088
    • Gold Member
    I think it would be possible to work under Windows XP but you will need of course a converter from RS232 to USB.
    This way I think it will be possible to make it work.
    For Windows 7 I cannot say for sure
    Best regards
    Spiros
  • 12-01-2010 3:05 AM In reply to
    Having put together a test setup tonight, I figured out specifically what I am looking for.
    Does anyone have the setup CD for Beolink PC Office? Specifically the Beolink PC setup application?
    I am assuming one installs the driver software for the Beolink PC Office to communicate with the Beolink Active box. The Beoport software won't work because it's looking for the device on the USB port.
  • 12-01-2010 5:31 AM In reply to
    • Spiros
    • Posts 1,088
    • Gold Member
    I might be able to help you. I'm pretty sure I have the software somewhere. Will check tonight and let you know
    Best regards
    Spiros
  • 12-01-2010 6:12 PM In reply to
    That would be great! I appreciate the help!
  • 12-02-2010 1:16 AM In reply to
    • Spiros
    • Posts 1,088
    • Gold Member
    Just sent you an email. Best regards Spiros
    Best regards
    Spiros
  • 12-02-2010 7:55 AM In reply to
    • Spiros
    • Posts 1,088
    • Gold Member
    John have already received the second email?
    Best regards
    Spiros
