Latest post 12-01-2010 11:20 PM by Eugene. 10 replies.
Page 1 of 1 (11 items)
  • 11-15-2010 11:24 AM
    • riis
    • Top 500 Contributor
    • Joined on 05-01-2007
    • Denmark
    • Posts 152
    CD 50 problem
    My CD 50 has stopped working. When I put a cd in the cd-tray and close it, it opens again and nothing else happens.
  • 11-15-2010 11:31 AM In reply to
    Re: CD 50 problem
    I had the same problem with mine. There are some contacts which detect if the CD tray is closed with a CD. I just gave them some contact cleaner (deoxit), and the machine came to life.
    -Søren
    Beocenter 9300, Beogam CD50, Beocord 5500, Beomaster 3400, Beomaster 4400, 2 Beogram 4000, Beomaster 8000, 2 beogram 8002, Beovox S-75, Beovox MS150.2, Beovox RL6000, Beovox S-35, Beomaster 6000, 2 Beocord 9000, Beocord 8004, Beocord 5000, Form 1, 2x Beolink 1000, Beo4, MX3500, LS4500. Born 1993.
  • 11-15-2010 1:12 PM In reply to
    • riis
    • Denmark
    • Posts 152
    Re: CD 50 problem
    Do I have to open the CD 50 in order to find the contacts or .....
  • 11-15-2010 2:39 PM In reply to
    Re: CD 50 problem
    It is easy to open the player, just the two screws in the back in each upper corner. Then you can slide the top cover off.
  • 11-16-2010 7:35 AM In reply to
    • riis
    • Denmark
    • Posts 152
    Re: CD 50 problem
    I have the top cover off, but I can't locate the contacts. When the tray slides in with the cd the cd doesn't rotate. It just raises a bit, stay in that position for 5 sec, falls down again and the tray slides out again.
  • 11-16-2010 6:06 PM In reply to
    Re: CD 50 problem
    A common problem with this model. Have a look at this thread:
    http://forum.beoworld.org/forums/t/30607.aspx
  • 11-19-2010 6:38 PM In reply to
    Re: CD 50 problem
    Maybe this will help. In the photo you can see two sets of contacts. an upper set and a lower set on the left side.
    I would look at the lower set on the left side. I had one with the same problem and cleaned and adjusted that set of contacts. solved the problem and it hasnt been a problem ever since. I really like the sound the CD50 produces and I also think it looks a little better than the later versions.
    Worth fixing if you have the time and patience fro fiddly type work. If not look into a CD 5500.
  • 11-30-2010 4:13 AM In reply to
    • riis
    • Denmark
    • Posts 152
    Re: CD 50 problem
    Eugene:
    Thanks Eugene. I have been away for some time so I had not seen your reply. I have loosened the four screws that hold the laser, but I can't remove it because of the four black "hooks". Anything else I must do?
  • 11-30-2010 5:23 PM In reply to
    Re: CD 50 problem
    Remove the block hook at the front of the player facing outside (easiet) and you will be able to jiggle the laser block out and expose the gears and contacts.
    Give everyting a good cleaning.
    I use deoxit on the electronic components then Isopropol on everything else
    I was thinking from memory that the contacts are visible when the laser block is al the way forward at the start play position.
  • 12-01-2010 1:23 PM In reply to
    • riis
    • Denmark
    • Posts 152
    Re: CD 50 problem
    I have located the problem to the contact which is driven by the big gear wheel. It seems as if the wheel doesn't turn enough to force the contact to the other side, but leaves the contact in the middle.
  • 12-01-2010 11:20 PM In reply to
    Re: CD 50 problem
    Ok  then,  did have one player where the flywheel had slipped loose from the cam underneath. Had to fit the two back togther and realign the flywheel so that everything would open close and load in proper sequence.
    As I recall it was a fairly easy fix.
    The other possibility is the contacort is out of kilter a bit. I have had that happen as well.
