Hi
Wondered if someone can point me in the right direction I have the above set up, I have been told my Bvis 3-32 17772664 Type 8523 is to old to be control the beomedia 1 via masterlink, which is fine, can anyone tell me, what kind of sensor do i need to make t work with the beo4, can I use a sensor from a Bvis4 if yes, can you tell me how it is wired, any help would be appreciated
