Hi at all,
just bought a Beoport in order to control my Mac Mini Media Center from main room as well as from link room. I don't have the IR eye so I connected it to Masterlink in the main room. Via PUC Apple Remote I am able to control Linkplayer (more or less).
Actually I thought that I will be able to control everything by Beo 4 PC command. Am I right that is possible without having the IR eye attached to the Beoport? It might just a question of the Option setting of the Beoport.
The goal is, to start Eyetv, Plex, iTunes, etc from Linkplayer by remote Beo4 (so far it works), but than it is not possible anymore to use the Exit button in the several programs as Eyetv for instance. When I want to use Remote Buddy, Linkplayer does not work anymore by PUC.
Who has a similar setup in use?
Your support is urgently requested (girlfriend's patience is running out ;-))
