1st March February 2012
Latest post 08-16-2011 10:14 PM by Razlaw. 12 replies.
11-10-2010 6:26 PM
Razlaw
- Joined on 04-24-2007
- Illinois
- Posts 1,770
We have a BV 7-55 and a a Bv 10-40 connected by Masterlink along with a Beosound 3000 and Beoport/iMac. The timer function in the 7-55 works perfectly to turn the TV on. Should I be able to activate the timer in the 10 as well and have it turn on in response to the timer in the 7?
Thanks!
Beosound 1, 5, 2000, and 3000
Beotime, Beotalk, Beocoms
Raeuber
- Joined on 12-02-2007
- Posts 986
Hello Razlaw,
although the BV10-40 has no own timer, it can response to the timer in your BV7-55:
Press MENU on Beo4 (twice if you have the HD-Module)
Press WIEDERGABE-TIMER (in german, in english it should be PLAY-TIMER)
Change from NO to YES
Hope it works!
Regards
Räuber
Razlaw
- Illinois
- Posts 1,770
Thanks! I thought it should work. I will try again when I get home as I am traveling at present.
My dealer said it would not work as the TVs are connected only by Masterlink, not by a video connection? We are in the USA if that makes any difference.
I did look at the FAQs on the B and O web page. If I am understanding correctly what they say, the TV has a power saving mode. If the power saving mode is activated the timer function will not work so perhaps I need to deactivate the power saving mode and try the timer again.
Razlaw
- Illinois
- Posts 1,770
So are you saying I can not have the 10 turn on via the 7's timer? No video, just audio?
stefan
- Joined on 04-16-2007
- 200 miles from Struer
- Posts 1,733
In Europe audio from video sources will be sent via video connection (coax). As far as I know there is no video link distribution in US models....(?)
But you can check it out.
Stefan
Razlaw
- Illinois
- Posts 1,770
As mentioned here there is no video distribution. But I am not trying to distribute video. I just want the timer to turn the 10 on and the 10 will produce it's own video and audio. The user manual for the 10 only makes reference to to having the 10 connected to some source with a timer, it does not limit it to an audio source?
stefan
- Posts 1,733
You set the timers in the mainroom in your videomaster: source, program/channel, date (days), start, stop...In your linkrooms you just set the timer, programmed in your main Beovision, to ON or OFF. This will activate your linksystem from standby and play the source you have selected for the timer in the mainroom. It is not possible to select a linkroom source for the timer. Audio from video sources are distributed via coax cable (antenna), so if you don`t have this video connection, there will be no sound on your link TV, only from audio sources, as audio from audio sources are distributed via Masterlink, which in your setup is connected. This is the way it works with european models, I`m not quite sure with US version. But as said, check it out.
Hope this helps
Stefan
Razlaw
- Illinois
- Posts 1,770
Thanks! I have been traveling so have not had another chance to try it. Hope to be home early enough today to try it.
Razlaw
- Illinois
- Posts 1,770
I have been able now to get the timer in the BV7 to turn the BV10 on via Masterlink. I program the satellite receiver connected to the BV10 to also turn itself on and select a channel at the same time. I was able to get this to work by setting the BV10 to option 2 and the BV7 to option 1, or by reversing the two options between the TVs. There are couple of issues with N. Music and N. Radio via a Beosound 5 with these options.
Razlaw
- Illinois
- Posts 1,770
I have not explored it either for the same reason.
Page 1 of 1 (13 items)
