Latest post 11-12-2010 6:05 AM by 11048437. 5 replies.
Page 1 of 1 (6 items)
  • 11-10-2010 4:46 PM
    BeoSystem 3- IR eye
    hi everyone,
    Tomorrow I.m going to buy a used Beosystem 3. The unit come without the IR eye and the IR blaster. I wonder if it is possible to use an the IR eye from my Beolink active in this unit. Also, I checked and the Bs3 does not use the same DIN connection so I>m wondering how should I modify the connections for the BS3?
    I called B&O dealer and it seems thet they are not selling IR blasters! Any ideea what I should buy in order to be compatible with the BS3?
    Thanks in advance,
    Kind regards....
    all sold!
  • 11-10-2010 5:12 PM In reply to
    • Seanie_230
    • Top 75 Contributor
    • Joined on 04-20-2007
    • Milton Keynes, England
    • Posts 962
    • Gold Member
    Re: BeoSystem 3- IR eye
    Hi there I used my eye from my Bellini passive as an external IR on my BV7/BS3 just needed a different wire configuration.
    Beovision 7 MKIV (Blu Ray)
    Beolab 9
    Beolab 6000
    Beo 4
    Beocenter 9300
    Apple TV
    SKY HD
    Optoma HD65 Projector
    Lintronic TT455-RT-238
    Beovision 3 MKII
  • 11-10-2010 5:28 PM In reply to
    Seanie,
    Thanks for your fast reply. How it looks the wire configuration? IR in in the BeoSystem looks like a serial port!!!!
    all sold!
  • 11-11-2010 6:10 AM In reply to
    • Seanie_230
    • Posts 962
    • Gold Member
    Well from how i understand it the eye is the same device but is wired differently for difference applications. (correct me if im wrong)
    The BV7 beosystem 3's connection is a headphone jack as it only uses IR no contrast stuff is needed. When used with the Beolink passive I had a din connection to the same IR i assume for use with the buttons and IR.
    I am not sure about the beosystem 3 it might be a different IR, A dealer should be able to get you the correct cable and confirm if you have the right IR.
    Beolab 9
    Beolab 6000
    Beo 4
    Beocenter 9300
    Apple TV
    SKY HD
    Beovision 3 MKII
  • 11-11-2010 9:28 PM In reply to
    You are absolutelly right. I need in fact only the Jack connection. I received today my Beosystem 3. I have to contact the dealer in order to have the PIN code. I bought it at an Police auction for a very very very good price!
    I wonder if anybody tried this connection on his Beosystem///
    http://www.beoworld.org/beotech/ir_eye_wiring.htm
    thanks
    all sold!
  • 11-12-2010 6:05 AM In reply to
    I can confirm that you can use a Beolink Eye and modify the connections as described here:
    Dealer quoted me 260$ for the original IR Eye. Now I have 260$ more in my pockets!
    all sold!
