Latest post 12-16-2010 5:58 PM by BeoMegaMan. 10 replies.
Page 1 of 1 (11 items)
  • 11-06-2010 4:49 PM
    Paint Your BeoSound 1 Grill?
    I have a BS1 in white which has seen better days on the grill. I am wanting to buy a new one, but not convinced it wouldn't be cooler to paint it a unique color of my own. I have seen a few limited editions which dealers have had painted for them by artists, but I would like to do my own. Any idea's on how I should go about it and what paint type of paint to recommend?
    BV7-40 MKIV, BeoVision Avant 32, BeoVision 8-32, BeoLab Penta MKIII, BeoLab 6000 x 3, BeoSound 9000 MKIII, BeoLab 7-4, BeoSound 4000, BeoPort, BeoVox S45-2, ML/MCL Convertors, A8's & Form 2's.
  • 11-07-2010 11:30 AM In reply to
    • Spiros
    • Top 50 Contributor
    • Joined on 09-03-2007
    • Thessaloniki GREECE
    • Posts 1,088
    • Gold Member
    Re: Paint Your BeoSound 1 Grill?
    I have done this in the past very successfully but I took the grill to a professional car painter. They really can do miracles and of course make any kind of painting you wish. Actually I'm now discussing with a fellow Beoworlder to buy a Beolab 2000 in order to paint it fully white so that I place it to my son's room. I think it should look great!!
    Best regards
    Spiros
  • 11-07-2010 3:55 PM In reply to
    Hi Spiros,
    How do you remove the grill of a Beolab 2000. Can't seem to find a way how to do.
    Has it been double taped?
    B&O item 1, B&O item 2, B&O item 3,...................B&O item 735
    Beovirus? What's that?
  • 11-07-2010 4:33 PM In reply to
    • Spiros
    • Posts 1,088
    • Gold Member
    Hi Leslie, I'm not sure yet!! I haven't bought it yet. Once I get in my hands I'll find the way!!!! But it should not be that difficult!!!! Will update if and when I do it. BR Spiros
    Best regards
    Spiros
  • 11-07-2010 5:57 PM In reply to
    Leslie:
    The grills slide upwards to remove them. I placed a credit card between the bottom of the speaker grill and the plastic of the speaker and wiggled it about, you wll see the grills move up a little and you can then keep sliding them up. Don't use anything that is metal or hard that may damage the grill or the plastic.
    Stoobie
  • 11-07-2010 6:09 PM In reply to
    Thanks Stoobie, will give it a try tomorrow!
  • 12-07-2010 3:48 PM In reply to
    Pics of the final product. I first tried a solid color but you could still see the dents and knicks in the front of the grill. I then decided to do a graffiti theme on it since it will go in my garage. All lacquer black, red, silver, spray finishes with some accents of gloss regular black and white. Finished with clear coat. Sorry for the poor pic as I snapped it with my iphone on the way out while it was drying.
  • 12-07-2010 5:02 PM In reply to
    That reminds me of Eddie Van Halen's guitar!
  • 12-09-2010 12:31 PM In reply to
    I was going for a industrial graffiti look, but I can see a little Eddie in it as well :)
  • 12-10-2010 2:43 AM In reply to
    • Michael
    • Top 500 Contributor
    • Joined on 05-20-2009
    • Glen Waverley, Victoria, Australia
    • Posts 245
    • Gold Member
    Looks great.  Very individual.  Nothing like a paint job to freshen up anything.  Well done.
    Michael.
  • 12-16-2010 5:58 PM In reply to
    Thank you kind sir, def. freshens the place up.
