Latest post 11-08-2010 9:08 AM by thavn. 4 replies.
Page 1 of 1 (5 items)
  • 11-06-2010 4:17 AM
    BEOVISION AVANT
    Hello,
    I have one beovision avant 28 RF with a fantastic picture when connected with an analogic cable.   I've just just bought another 32 RF last version ( with MP3 DVD).
    With this one, the picture with analogic cable  is not good whereas with freeview it's good but not so fantastic as the 28 RF with ordinary cable .
    Do you think it's normal or has the TV got a problem ?
  • 11-06-2010 4:33 AM In reply to
    Re: BEOVISION AVANT
    Hi, I have got a rf 32 and a friend has a rf 28 I think his picture is sharper than mine!  Are you using the same analog cable?  also if your splitting the aerial feed try a signal booster??
    Please define not good? (as in poor signal)
    cheers Nick
  • 11-06-2010 4:45 AM In reply to
    Re: BEOVISION AVANT
    Thank you for your reply.
    I use the same cable and I have a booster for the signal.
    32 on the RF analog I also have a problem switching sound on some TV channel.
  • 11-06-2010 5:58 AM In reply to
    Re: BEOVISION AVANT
    Try another source - DVD via SCART for instance. That will tell you if it is the picture or the tuner/connection.
  • 11-08-2010 9:08 AM In reply to
    Re: BEOVISION AVANT
    The 28" is smaller than the 32". Therefore also sharper picture. Can it be that simple?
    BV10, Avant DVD, BL5, BL4000, BS2300, BV6-26, MX 4002, 2xBeocom 6000, LC2
