Latest post 11-05-2010 3:21 PM by SHEFFIELD. 7 replies.
Page 1 of 1 (8 items)
  • 11-04-2010 12:07 AM
    • Olof
    • Top 500 Contributor
    • Joined on 05-12-2007
    • Posts 141
    Which speaker in the kitchen ?
    Is BeoLab 3500 a good choice ? Or should it better be a small BV 10 32" ? Any informations about if the BL 3500 also will get his update "soon" ?
  • 11-04-2010 3:34 AM In reply to
    Re: Which speaker in the kitchen ?
    BL3500 vs BV10-32?
    Do you want sound or a full TV set with everything.
    If sound is what you want the Bl3500 is a good choice. But you can also try the BL2000 which sounds very well and is quite a cheap option now. I use a BL2000 on my terrace and love it. Depends also a little on the space available.
    BeoVision 8-40 / BeoVision 8-32 / Beovision 6-26 / BeoSound 3200 / BeoSound 1 / BeoLab 3 /  Beolab 6000 / Beolab 2000 / Beoport / Beomedia 1 / 3* Beo4 /BeoCom 5 with VOIP
  • 11-04-2010 4:32 AM In reply to
    If you only want sound, i´ll recoment Beolab 2000 & Beolab 3500 as well.
    I have the BL2000 ind my kitchen my self. Wink
  • 11-04-2010 4:57 AM In reply to
    BeoLab 2000 is more robust and compact than BeoLab 3500, so it would be the ideal choice for a kitchen or bathroom (I have one in the bathroom); as others said, it is also much cheaper and has source, volume & step controls on it.
    Reunion Island is greeting you!
  • 11-04-2010 5:32 AM In reply to
    • Daniel
    • Top 50 Contributor
    • Joined on 04-17-2007
    • Svinarp, Sweden
    • Posts 1,284
    BeoLab 2000 everyday! We have two, and the one in the kitchen is the most used speaker in da house. Compact, excellent sound, easy to clean (no cloth) and so easy to change volume (without remote).
  • 11-04-2010 6:27 AM In reply to
    • msinn
    • Not Ranked
    • Joined on 12-11-2007
    • Germany
    • Posts 48
    • Gold Member
    I just decided to go for a pair of BeoLab 4 mounted to the ceiling and match the color of the coviering to the colors used in the kitchen.
    msinn
  • 11-05-2010 8:17 AM In reply to
    • Spiros
    • Joined on 09-03-2007
    • Thessaloniki GREECE
    • Posts 1,088
    • Gold Member
    Would go for a Beolab 2000. Robust, Cheap and excellent for everyday use. But in case there is big kitchen space, I think it would make sense to use the Beolab 3500 as it is more elegant and can be placed everywhere in the wall giving a very nice decor as well.
    Best regards
    Spiros
  • 11-05-2010 3:21 PM In reply to
    I would highly recommend the BeoLab 3500 - looks and sounds superb!
