BeoVision 7 40 MKII with STB Topfield 5810 PVR (500MB)
 Has anyone got any experience/recommendations in regards to using the BV7 40 with a Topfield 5810 PVR?
Connection setup – Video and Audio via Scart
·      Should I simply connect the TF5810 via a Scart cable with the BV7?
Connection setup – Video via DVI and Audio via ????
·      Or would it be better to use the DVI port for the Video signal?
·      Has anyone used a DVI to HDMI convertor and/or DVI to HDMI cable? Is there any difference between them (quality, etc.)?
·      For the Audio signal, which is the optimum connection (Scart, digital)????
IR remote booster for Beo4
·      I believe that this should be a pretty straightforward procedure.
·      Is the IR sensor on the TF5810 pretty simple to locate
BV7 software update for Beo 4
·      The BV7 has been recently ‘flashed’
Topfield TAPS
·      Are there any key TAPS to use
·      Are the TAPS downloaded directly onto the STB or via computer (MAC)
Any advice would be appreciated.
Thanks very much.
