Latest post 11-24-2010 6:56 AM by Dillen. 5 replies.
Page 1 of 1 (6 items)
  • 11-03-2010 6:51 PM
    Tuning past 104 with a Beomaster 3000-2?
    I'm in the UK & usually listen to BBC Radio 3, sometimes Radio 4, which are 91.0 & 93.2MHz. However, a friend asked about listening to a ("headbanger's") programme at the top end of the dial - around 106. (I do know that this region exists... I just prefer not to go there usually!).
    Does anyone have any experience of modifying the Beomaster 3000 & 4000 to receive the high frequencies, which I think were only for 'emergency service' use when the receiver were first sold? I realise that, if modified, the tuning scale would be even less use than it is now; but could, perhaps, one or two of the presets be modified and 'tuned by ear'?
    Thanks for your thoughts,
    Adam K, London.
  • 11-04-2010 3:13 AM In reply to
    Re: Tuning past 104 with a Beomaster 3000-2?
    Actually, some 3000's with 108 mHz scale were made, but they are not as common as the one with 104 mHz scale Wink
    I don't know if the tuner (variable capacitor) is the same on the two, it is likely that your tuner is only made for going to 104 mHz.
    Beocenter 9300, Beogam CD50, Beocord 5500, Beomaster 3400, Beomaster 4400, 2 Beogram 4000, Beomaster 8000, 2 beogram 8002, Beovox S-75, Beovox MS150.2, Beovox RL6000, Beovox S-35, Beomaster 6000, 2 Beocord 9000, Beocord 8004, Beocord 5000, Form 1, 2x Beolink 1000, Beo4, MX3500, LS4500. Born 1993.
  • 11-15-2010 9:15 PM In reply to
    • yachadm
    • Top 100 Contributor
    • Joined on 06-24-2007
    • Jerusalem, Israel
    • Posts 687
    I haven't had a look at the schematics for the BM3000, but if it is a voltage-tuned unit, you can certainly modify it. The tuning scale just wouldn't be accurate.
    I did my BM3400 like that.
    You'd need to look at the schematics to determine if your's is a voltage-tuned unit.
    Learn from the mistakes of others - you'll not live long enough to make them all yourself!
  • 11-17-2010 9:46 AM In reply to
    If it has station presets, it is most likely voltage tuned. Because that would be very hard to do with variable caps.
  • 11-18-2010 10:28 PM In reply to
    • Evan
    • Top 25 Contributor
    • Joined on 12-15-2008
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    Type 2402 goes to 108Mhz.
    Evan
  • 11-24-2010 6:56 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Beomaster 3000 build series 1-3 goes to 108MHz
    Series 4 and later only goes to 104MHz.
