Latest post 11-03-2010 8:42 AM by Dillen. 3 replies.
Page 1 of 1 (4 items)
  • 11-01-2010 12:28 PM
    BM 4500 Capacitor Kits and Installation
    A newbie question - I have read "Dillen" to be the guy to go to for any repairs of beomasters.
    I am in the process of securing a beomaster 4500 and not sure would need any capacitors replaced - its's made in 1992
    Question:
    1. How would I know if the unit needs new capacitors?
    2. If so how do i or from where do I get them?
    3. Is this some thing I can install myself - assuming i get the tools to do this
    4. Since "Dillen" is not in USA - I assume it will be costly affair to ship and get replaced or serviced.
    5. Anyone please suggest a local - USA east coster who could do this for reasonable price.
    Thanks guys
    Beovox RL 60.2, RL 6000, S45-2, CX 50, Cona, Beolink Passive, MCL2P, BM4500, Beosound 1, Beocenter 2500, Beolab 2500, Besound 4000, Beolab 4000, Beocom 6000, A8, Beosystem 1
  • 11-02-2010 3:39 PM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: BM 4500 Capacitor Kits and Installation
    A capacitor kit is available for the Beomaster 4500 but it's my experience that
    most Beomaster 4500's are still doing fine with the original components but of course
    it won't last forever and if there is a fault present, it will have to
    be diagnosed and fixed.
    Answers to your questions:
    1. If it works and sounds good, no problem.
    The most typical symptoms of bad caps are :
    - A weak or missing channel
    - Background hum
    - General operation feels sluggish
    2. Kits are (made by and) available from me.
    3. I would recommend taking the task to a skilled tech guy with an antistatic (ESD) workbench.
    Basic electronic skills and a good amount of soldering is involved.
    Not all repairers will have all the necessary components in the drawer and buying from a repairshop
    may be an expensive way to get the parts but most repairers will gladly mount a kit if you
    bring one along with the Beomaster. Ask your repairer.
    4. I'm in Denmark. I have done countless repairs from all over the world but shipping
    back and forth is not cheap, customs can sometimes be a headache and I'm sure you should
    be able to find a local repairer, willing and able to fix your Beomaster.
    It's still a fairly new model.
    5. The only one I know of in the US is Atlantic Systems. I have only heard good about them.
    I'm sure they will have all the parts needed or at least an idea about where to get them but as
    I haven't tried them myself I cannot tell you much about their pricing etc.
  • 11-02-2010 11:51 PM In reply to
    Your patience is very much appreciated in answering the questions.
    If you think its appropriate please PM the cost of a replacement kit.
    Thanks again
  • 11-03-2010 8:42 AM In reply to
    • Dillen
    • Posts 5,008
    Obviously, I cannot tell you if you need any parts, simply because I don't know the condition of your Beomaster.
    I suggest you check the condition (is it working and sounding good) and we can then see if it needs anything at all.
