Latest post 10-30-2010 10:42 AM by Dennis. 7 replies.
Page 1 of 1 (8 items)
  • 10-29-2010 10:56 PM
    Cleaning steel
    What do you use to clean the metal shiny bits on your speakers?  The stuff I'm using just clouds it up.
  • 10-30-2010 1:57 AM In reply to
    • stotty1111
    • Top 75 Contributor
    • Joined on 12-16-2007
    • UK / France - Nth Worcestershire/Finistere
    • Posts 924
    • Gold Member
    Re: Cleaning steel
    do a google search on micro mesh - a product for declouding perspex aircraft screens - i've used it carefully on bl5000 panels with success
    as  i recall its about £15?
    tony
    I always try to operate using/following the KISS principle --  Keep it simple stupid!
  • 10-30-2010 2:41 AM In reply to
    Re: Cleaning steel
    I´m using baby oil
  • 10-30-2010 4:36 AM In reply to
    Re: Cleaning steel
    Coconut oil is advised by Bang & Olufsen for the stainless steel panels of the Penta.
  • 10-30-2010 5:19 AM In reply to
    Re: Cleaning steel
    If they are really mucky try Solvo Autosol first then a bit of baby oil to keep a nice sheen.
  • 10-30-2010 5:49 AM In reply to
    Re: Cleaning steel
    Glass cleaner. Microfibre cloth. Job done.
  • 10-30-2010 7:35 AM In reply to
    Re: Cleaning steel
    I also use glass cleaner for my B&O, but once a year or so I use some isopropanol for the alu surfaces to clean properly Stick out tongue
    Beocenter 9300, Beogam CD50, Beocord 5500, Beomaster 3400, Beomaster 4400, 2 Beogram 4000, Beomaster 8000, 2 beogram 8002, Beovox S-75, Beovox MS150.2, Beovox RL6000, Beovox S-35, Beomaster 6000, 2 Beocord 9000, Beocord 8004, Beocord 5000, Form 1, 2x Beolink 1000, Beo4, MX3500, LS4500. Born 1993.
  • 10-30-2010 10:42 AM In reply to
    • Dennis
    • Top 500 Contributor
    • Joined on 02-01-2009
    • Denmark
    • Posts 172
    • Gold Member
    Re: Cleaning steel
    But there is a problem if you use glasscleaner and other things that removes the thin layer of oil that's on the surface. The layer protects the surface aigainst fingerprints and so on. But if the layer isn't there, fingerprints will "burn in" or oxidide the surface, and they can be hard to get off again! Unless you ofcourse polish the surface, but on a pair of Beolab 3000, 4500 or 5000 I think, that the 'Bang & Olufsen' maybe will be polished of?!
    I use something called 'Sterling'; a product made for stainless steel, that polishes the surface slightly and also contains oil that protects the surface.
    - Dennis
    I was borned with a Beolink 1000 in my hand!
    Ever seen a Beomaster 6001? I have one! Look here.
    Main system: Beovision AV9000, Beocenter 2300, Beosystem 3500, Beolab Penta MKIII, Beolab 3000, Beogram 6500, Beolink 1000, Beolink 5000, Beolink 7000
    Wish list: Beolab 2,
