Latest post 10-30-2010 2:00 PM by Harry2008. 6 replies.
Page 1 of 1 (7 items)
  • 10-28-2010 2:46 PM
    MOTS not working with WAV files.
    MOTS on my BS 5 doesn`t work, my dealer told me the system can`t analyse WAV files and that`s the problem. Does anyone else have the same experience?
    See hear feel B&O.
  • 10-29-2010 7:35 PM In reply to
    • Electrified
    • Top 150 Contributor
    • Joined on 10-05-2009
    • Greater Copenhagen, Denmark
    • Posts 404
    Re: MOTS not working with WAV files.
    I don't know whether the BS5's mots does or does not work with wav-files, but why not make all your wav-files into lossless files?
    That way you will be able to tag them much better, and you will have an album collection taking up approximately 60 percent of your wav-collection.
    Edit:
    And lossless is, of course, lossless Yes -  thumbs up
  • 10-30-2010 10:20 AM In reply to
    Ok, do you know of a program that can convert Wav files to lossless?
    See hear feel B&O.
  • 10-30-2010 11:32 AM In reply to
    If you're on Windows, foobar2000 is a free player which will also convert pretty much anything to anything. You may need to download some components or encoders separately and the tagging / filename conversion will need some thought - read the instructions, or be prepared to start over many times! Smile
    -mika
  • 10-30-2010 11:45 AM In reply to
    • Electrified
    • Posts 404
    gabriel:
    Yes, iTunes on Windows can convert to WMA lossless which is what you need on the BS5, Foobar as is mentioned,  and my favourite: The paid-for version of Winamp.
  • 10-30-2010 1:26 PM In reply to
    I use X Recode and it also works like a charm, I had a few albums in wav format and they were converted both to ALAC and WMALossless without any problem.Smile
    Reunion Island is greeting you!
  • 10-30-2010 2:00 PM In reply to
    On the Mac I am using Switch from NCH Software.  Works great, although not free.
