Latest post 10-28-2010 3:53 PM by Blackrix. 2 replies.
Page 1 of 1 (3 items)
  • 10-28-2010 1:05 PM
    • scuba
    • Not Ranked
    • Joined on 12-28-2008
    • Posts 48
    How do you play side B on a reel to reel ?
    Hi, i have a Beocord 1200 and finaly found a reel with music i actualy like on ebay, my maybe stupid questions is how do you play side B on these things? And is it a special trick to use when you lock the end of the tape to the empty reel before winding the tape over to it?
    Jon
  • 10-28-2010 1:33 PM In reply to
    Re: How do you play side B on a reel to reel ?
    Are you certain that the tape you have was recorded in a format that allows this.
    You have two track - stereo one direction only
    You have two track - two tracks of mono - you turn the tape around and play the other direction
    You have 4 track two lots of stereo - turn tape around and play
    They are not compatible, though some machines can handle a couple of formats but usually they cannot handle all possible formats
    Some machines can handle several formats, but only record in one format.
  • 10-28-2010 3:53 PM In reply to
    A four track machine can play a two track recorded tape. The other way around (play four track on a two track) is not possible unless the recorder is equipped for this (BeoCord 1500 De Luxe, BeoCord 1800 DeLuxe and BeoCord 2400 DeLuxe).
