1st March February 2012
Latest post 11-01-2010 2:48 AM by SWISS_2. 5 replies.
10-27-2010 10:33 PM
sodoi18
- Joined on 02-06-2010
- USA
- Posts 194
Very faint hummmm from beolab 4000
From one of beolab 4000 connected to ouverture I hear a very faint hummmm, almost like a wavy
Sound almost like the sound you hear when the tape is running but empty with no track.
One thing I noticed is if hold the power cord or metal part of beolab the noise vanishes. It's coming only from one
Speaker.
What could be wrong. The hum is only audible at very very close to speaker
Beovox RL 60.2, RL 6000, S45-2, CX 50, Cona, Beolink Passive, MCL2P, BM4500, Beosound 1, Beocenter 2500, Beolab 2500, Besound 4000, Beolab 4000, Beocom 6000, A8, Beosystem 1
Jonathan
- Joined on 05-03-2007
- Melbourne, Australia
- Posts 1,164
Re: Very faint hummmm from beolab 4000
Try switching the cables from one speker to the other. If the hum is present on the other speaker, then it's your cables. If the hum remains on the original speaker then you'll have to take it to service...
sounds like cables though
My B&O: 2009 Catalogue and Pricelist
SWISS_2
- Joined on 04-16-2007
- Neuchatel, Suisse
- Posts 552
Agree with our member down under: Sounds like the cables.
A pulsating, or " wavy " sound would indicate electrical source interference, through the cable, or from a nearby source.
In addition to the good comments above, you might also consider checking the switches in the back of each of your Beolab 4000 speakers (L-R), and also trace down your main electrical source for proper grounding.
Nice avatar.
sodoi18
- USA
- Posts 194
Thanks for all the good input.
What did u mean by checking the L/R buttons. Is it to make sure that both are not on L or R.
sodoi18
- USA
- Posts 194
Beocom 6000 was the reason, it was too close
SWISS_2
- Neuchatel, Suisse
- Posts 552
Good to hear you identified the source.
Page 1 of 1 (6 items)
