1st March February 2012
Latest post 10-26-2010 5:52 AM by Eugene. 21 replies.
10-24-2010 9:25 PM
sodoi18
- Joined on 02-06-2010
- USA
- Posts 194
Which Beomaster amplifier to get?
With requirement to play beovox rl 60.2 speakers and input from a ipod, which will be a good one to get?
Beovox RL 60.2, RL 6000, S45-2, CX 50, Cona, Beolink Passive, MCL2P, BM4500, Beosound 1, Beocenter 2500, Beolab 2500, Besound 4000, Beolab 4000, Beocom 6000, A8, Beosystem 1
Søren Mexico
- Joined on 09-13-2007
- Mexico city
- Posts 1,621
Re: Which Beomaster amplifier to get?
I agree with Spiros, but take a look at the Beomaster 4500, its build in the same year range as RL 60s but in my opinion also a beautiful piece of art, and after getting one of these, I'm shure you will get the Beovirus and start completing your BeoSystem 4500
Soren
Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!!
Søren Hammer
- Joined on 01-07-2008
- Esbjerg/Denmark
- Posts 554
Hello,
Sure, the RL series fits well to all Beomaster 1900/2400 and 5000 family products, Just about preferences about the appearance and functionality. the 5000 family is more compact, but the 1900/2400 family has the looks
Another choice can be a Beocenter 8500/9000/9300/9500 model, with integrated cassette and CD player, then you'll just need a Beogram turntable
I would recommend periodically correct gear to go with your RL's, but it will equally work fine, even great with older Beosystems.
-Søren
Beocenter 9300, Beogam CD50, Beocord 5500, Beomaster 3400, Beomaster 4400, 2 Beogram 4000, Beomaster 8000, 2 beogram 8002, Beovox S-75, Beovox MS150.2, Beovox RL6000, Beovox S-35, Beomaster 6000, 2 Beocord 9000, Beocord 8004, Beocord 5000, Form 1, 2x Beolink 1000, Beo4, MX3500, LS4500. Born 1993.
sodoi18
- USA
- Posts 194
Initially i started the RL 60.2 set-up in basement as a link room with a beolink passive. However, I now want to make it stand alone.
I read a lot about Beomaster 4500. There seem to be a more like in the forum for the Beomaster 4400. I may want to start watching on ebay for a 4400 or 4500 - not sure how much different they are - any inputs in that regards?
sodoi18
- USA
- Posts 194
Also please share some numbers on how much I should be paying for a clean beomaster 4400 or 4500
Søren Mexico
- Mexico city
- Posts 1,621
For differences 4400-4500 check in the product list
sodoi18
- USA
- Posts 194
Thanks Soren,
I started reading on it... They seem to be a lot different then common.
sodoi18
- USA
- Posts 194
Its little confusing to see names for products not matching the family names...check this link
http://beocentral.com/receivers
The Beomaster 4500 is listed under 1900 family..and there is one beomaster 4400 under 3000 family
burantek
- Joined on 05-04-2007
- SE USA
- Posts 6,214
sodoi18:
They are both correct.
You are looking at two completely different animals. Both excellent in their own way.
The 4400 is perhaps one of the best BM's ever made and is outstanding on its own.
The
4500 is the last of the "flats" and highly desired. Wall mountable and
can be joined by the rest of the BS4500. You want at least SW2.1 so that
you have 2-way.
Medogsfat
- Joined on 02-21-2007
- *Moderator* Leeds, Yorkshire
- Posts 4,045
For pure versatilty you cannot beat the Beomaster 5500. Loads of inputs which are mirrored with DIN & RCA sockets. A very good amp & will match the RL60.2's very well.
Can be controlled with any of the remotes (except the Beolink 5000) from a Beolink 1000 onwards. I have one which I use for all sorts of applications - from using as part of a system 5500 to testing other equipment. You can add other components at your liesure as with the 4500.
Chris.
j0hnbarker
- Joined on 04-16-2007
- LS28/GB
- Posts 2,002
sodoi18:
Are looks a key thing for you, in terms of either fitting into an existing interior and/or making a statement? Some Beomasters are more attractive than others...
sodoi18
- USA
- Posts 194
certainly looks are important.
Form what I have read here the flat beomaster 4500 and beomaster 5500 are top on the list.
j0hnbarker
- LS28/GB
- Posts 2,002
sodoi18:
The 4500 is certainly a good looking Beomaster, with the 5500 less so in my opinion (though it is more versatile as Chris pointed out). There are a couple of nice shots of the 4500 in the 'Flash Your B&O' thread. You might also see some other nice shots of other Beomasters in situ that you might find interesting as you contemplate what you would like to buy :)
sodoi18
- USA
- Posts 194
After all the inputs I am leaning towards a 4500. How much max, I should plan to spend..Is $200 high?
Any Ideas?
burantek
- SE USA
- Posts 6,214
In the states... I would consider that on the low side.
Buy the
best one you can afford. Cosmetics are key to these as the mirrored
panels do not hold up well. Look at them the wrong way and they will
scratch!
Pay attention to the SW level as mentioned. Not that the
1-way systems are bad, but you may regret it later should you ever buy a
BL5000 or 7000.
Medogsfat
- Posts 4,045
j0hnbarker:
No doubt about it - the 4500 is much better looking than the box which is the 5500 and will sit really well even as a stand alone unit. Performance wise (for passive speakers) though the 5500 beats it.
The 4500 isn't lacking in inputs either :- Phono, 2 X tapes, Aux & CD, all are 7 pin DIN though. Either tapes or the Aux input will be fine for an iPod connection.
$200 is a very good price for one, but as has already been pointed out, cosmetics are really important when it comes to price with these.
Chris.
Jonathan
- Joined on 05-03-2007
- Melbourne, Australia
- Posts 1,164
I would consider a Beomaster 6500 or 7000. The reason for this is that they are a bit more flexible. You can use passive or active speakers, so if you decide to upgrade to Beolabs you'll be ready..
My B&O: 2009 Catalogue and Pricelist
sodoi18
- USA
- Posts 194
To my knowledge beomaster 4500 can power a beolab.
Am I wrong?
beocool
- Joined on 10-17-2007
- the Netherlands
- Posts 5,514
sodoi18:
Am I wrong?
You're right!
Eugene
- Joined on 12-17-2008
- Posts 589
A setup I sometime have used is a Beomaster 3000, Beogram 3000 and CDX from the mid 80's along with a set of Redlines. works well and looks good together
Not as versatile as the other sets mentioned but as a stand alone system it is just fine.
Page 1 of 1 (22 items)
