Latest post 10-25-2010 5:09 AM by Hildebrand. 1 replies.
Page 1 of 1 (2 items)
  • 10-24-2010 1:00 PM
    CABLES NEEDED TO CONNECT BS1 AND BEO4 50" PLASMA
    Greetings all,
    I am a new B&O owner and am still getting a handle on the unique equipment.  I own a BS1 and a Beovision 4 - 50 Plasma with the following model/part numbers and wanted to know can I use a normal component cable to connect the two from the projector out ports on top of the BS1.  I tried this with no success, but did notice there are additional (4th and 5th) ports for H/V sync I presume.  Do I need to purchase a 5-way component cable that has RGB+HV?  I also notice a serial port, must that be connected as well?  If so, I would appreciate any response and any links to where I can purchase the requisite cables.
    BeoSystem 1                      BeoVision 4 - 50 MkII
    Type - 8480                         Type - 8951
    Item - 1800403                     Item - 1895126
    SW - 4.7
    Thanks!
  • 10-25-2010 5:09 AM In reply to
    Re: CABLES NEEDED TO CONNECT BS1 AND BEO4 50" PLASMA
    walla210,
    Welcome to the B&O community!
    As you may already know the BS1 supports 480p and 1080i scanning formats.  The only connection that supports 1080i resolution as input is the Top Panel component DTV IN.
    As for the connections on the Top panel your PROJ OUT is a RGBHV Cable (15Pin D-Sub) connection for connecting a plasma screen or a large-screen projector, the DTV IN - Five sockets are available for connection of component signals from e.g. a high Definition set-top box: Y/G, Pr/R, Pb/B, H and V.
    I went out and purchased a 9.84 ft. Silver Serpent VGA Breakout Cable, hd15 to 5 RCAs ( $79.95 currently ) from Better Cables ( http://www.bettercables.com/vga-breakout-cable.aspx ) seeing that, that is how I got a picture to show on my BeoVision 4 - 50.  There price has gone down quite a bit since I purchased mine!  This connects from the 15Pin D-Sub/PROJ. OUT into the BeoVisions RCA Inputs as well as the RS 232 Cable ( 6270808 ) USB in the Data connection port on the Rear connection panel of the BS1 into the serial RS232 input on the BeoVision 4.  You may even just get a direct 15 pin D-sub RGBHV Cable as shown in the Cinema Installation Setup Manual.  You can get the exact 15 pin designation in order to get a cable made if need be from the Cinema Installation Setup Manual as well.
    Then via a Zektor HDS4 ( http://www.zektor.com/hds4/index.html ) component video and digital optical toslink/Coax audio switch I share the DTV In connection between my DirecTV Box and PS3 in order to run them at their highest resolution that the BS1 will recognize 1080i.  The switch is then connected into the Top Connection Panel DTV IN as well as Digital Toslink out from the switch into the Rear Connection panel STB OPTICAL IN.
    The DTV IN is the only connection that can handle the 1080i input.  As for the rear panel panel connections on the BS1 you are limited to the lower resolution by the RCA (Composite) and S-Video (Y/C Seperated) which I believe is 480p.
    Only other definite thing I can think of is that you need to enter the Menus of your BS1 and setup the attached Components as well as attached speakers.
    I would also recommend heading over the the Products page and downloading the User/Service Manuals that are available for the BS1!
    Conjureone
    BeoVision 4-50 MkII, BeoSystem 1, Zektor Switch, DTS box, BeoLink Passive, BeoVox Cona, BeoLab 1, BeoLab 3500, BeoLab 6000, BeoLab 4000, BeoLab 4, BeoLab 3000, BeoMedia 1, BeoMaster 5, BeoSystem 3 Type 9621
