Latest post 10-24-2010 3:45 AM by bussreply. 4 replies.
Page 1 of 1 (5 items)
  • 10-23-2010 6:23 AM
    Remote Control
    At the ripe old age of 58 thought it time I started to look at Bang & Olufsen products. I wanted to start with a stand alone cd but it seems without other items the functions seem to be very limited. Is there not a remote to work the stand alone cd player. I rather liked the look of the Beogram cd 6500. They seem reasonably priced on Ebay but of course they dont mention the limitations. Any advice would be appreciated. Regards Fred.
  • 10-23-2010 7:16 AM In reply to
    Re: Remote Control
    The only option is a CD50 with the optional remote control. The remote was very rarely specified when new and nigh on impossible to find now. Its not just the remote control, the CD50 must have the remote board fitted also.  Then you have the fact that the CD50 will break down as they are not that reliable.
    You would be much better off buying a CD6500 and a Beomaster 6500. That would enable remote control through either MCP6500, BL1000 or Beo4 plus you can listen to the radio and connect your mp3 player to it.
  • 10-23-2010 7:20 AM In reply to
    Re: Remote Control
    The CD50's are extremely reliable, as the laser unit is sturdy built, the motor and drive mechanisms may need some lubrication. One great machine, though I might go for a CDX Wink
    Beocenter 9300, Beogam CD50, Beocord 5500, Beomaster 3400, Beomaster 4400, 2 Beogram 4000, Beomaster 8000, 2 beogram 8002, Beovox S-75, Beovox MS150.2, Beovox RL6000, Beovox S-35, Beomaster 6000, 2 Beocord 9000, Beocord 8004, Beocord 5000, Form 1, 2x Beolink 1000, Beo4, MX3500, LS4500. Born 1993.
  • 10-23-2010 2:42 PM In reply to
    Re: Remote Control
    The laser on the CD50 is undestructible. The rest of it, I have to say, is not! I have a non workking CD50 sitting here as I type! Laughing
  • 10-24-2010 3:45 AM In reply to
    Re: Remote Control
    Thanks for information everyone. Looks like need to invest a little more. Much appreciated information.
