Latest post 10-21-2010 10:30 AM by talisman. 3 replies.
Page 1 of 1 (4 items)
  • 10-21-2010 9:03 AM
    • Christer
    • Not Ranked
    • Joined on 01-18-2010
    • Stockholm
    • Posts 13
    • Silver Member
    Controlling external devices via puc
    Hi!
    I have a BV7 MK4 connected direct via HDMI to a Humac HD 1000 and via a Gefen HDMI Splitter to a Tvix and a PS3.
    All these devices are set to go ON and OFF togheter with the TV. This works 7 of 10 times but sometimes
    the external devices dont start or won´t go to stby.
    This is very annoying sinve I have to go and push ON and OFF on the boxes manually and also that I can´t know if they are on or OFF if i don´t go and check.
    Does anyone know anyway to make this work?
    Brgs
    Christer
    BV7-40 MK IV, BS/BM5, BL9, BL3, BL2
    BV10-32 MKII, BL11
    MAC MINI, TVIX, GEFEN, HUMAX, PS3
  • 10-21-2010 9:38 AM In reply to
    Re: Controlling external devices via puc
    Is that long ago that you got the PUCK codes flashed in your TV?
    If you do not have the lates revicion on the PUCK kod, you
    can you experience these problems.
    BeoVision 4 - 50 HD -  Beo5 - Beolab 5 - Beolab 7-1 - Beolab 6000 .
  • 10-21-2010 10:11 AM In reply to
    • Christer
    • Not Ranked
    • Stockholm
    • Posts 13
    • Silver Member
    I think it is 6 month ago. I also have the same problem with controlling GEFEN.
    Work really good sometimes but it hardly repsonse other times.
    BV10-32 MKII, BL11
  • 10-21-2010 10:30 AM In reply to
    Make sure you get your TV flashed with the latest version of the PUC tool in the B & O service tool MKII. I gote the same problem with the Humax HDPVR 1000C and Tvix 6500. After flash whit the latest PUC kode the problem is solved.
