Latest post 07-02-2007 10:02 PM by beobres. 5 replies.
Page 1 of 1 (6 items)
  • 06-29-2007 9:30 PM
    BeoSystem 3/BeoVision 7-50 set up: Red blinking light on remote eye
    Has anyone experienced this issue?  When I power off (put into standby) the BS3/BV7 system, the red light on the remote eye goes solid red, starts blinkingand keeps blinking.  One more press on the Beo4 remote standby button turns it off.
    Is this normal?  Assuming not, what is the fix? If it is of any importance, the other issue is that the DVD player (Samsung blu-ray) does not power on or off with the system.  Also connected are a Scientific Atlanta HD PVR cable box and Beosound 9000.
     The dealer doesn't have any ideas why the light keeps blinking.
     As always, thanks for your help~~
    Todd
  • 06-30-2007 10:12 AM In reply to
    Re: BeoSystem 3/BeoVision 7-50 set up: Red blinking light on remote eye
    There came a new SW update 3.1, June 21. that should solved problem when powering off..
    But don't know if it's this B&O mean by power off Problem (blinking red)..
  • 06-30-2007 10:20 AM In reply to
    I never knew there is a Beovision 7-50 ?
    Have I missed something?
  • 06-30-2007 10:55 AM In reply to
    I think he means BV4-50 or BV7-40 Smile
  • 06-30-2007 6:25 PM In reply to
    • Max
    • Not Ranked
    • Joined on 04-19-2007
    • Devon
    • Posts 64
    Yes, I had the same issue recently - see thread (http://forum.beoworld.org/forums/thread/24069.aspx). I was upgraded to 3.1 today and I'll post if any further problems occur.
    My B&O is in my Bio.
  • 07-02-2007 10:02 PM In reply to
    Sorry-- yes, I meant the BV 4-50.  The mind is a terrible thing to waste...
    Thanks for all the input.  I've sent comments to my dealer, and will see if the flash he did is for the 3.1 when I get back to town next week.
