Latest post 11-10-2010 4:49 AM by Stonk. 5 replies.
Page 1 of 1 (6 items)
  • 10-17-2010 6:10 PM
    • jl13
    • Not Ranked
    • Joined on 10-17-2010
    • Posts 8
    Beocenter 9500 only 10 radio stations ....
    Hello everybody,
    fresh arrived on beoworld today, have try to find a little help among the "beocenter 9500 " thread, but don't find anything looking like my problem, but prehaps somebody have an idea. My beocenter 9500 from 1993, stops to display the 20 radio stations on the upper glass panel, and each "number" from 11 to 20 are missing, when i select one, say 12, the number blinks, but return to the last working number...from 1 to 10. any reply will be really appreciated, as i don't even know where to start to search !
    Sorry for my poor english, but as you already understand, i'm from france...
    thank you
  • 10-17-2010 6:38 PM In reply to
    Re: Beocenter 9500 only 10 radio stations ....
    Hello and welcome to BeoWorld!
    The problem you discribe is not that big. BeoCenter 9500 only shows the presets on the top display that are programmed. So you probably don't have any radiostations programmed on presets 11 to 20. Just search a radio station, store it on preset 11 and you will see that you can go to preset 11 after that!
  • 10-19-2010 9:21 AM In reply to
    • jl13
    • Not Ranked
    • Posts 8
    Thank you, but it doesn't help... because when I play a CD, only the first ten numbers display, even if the CD contains more tracks. when the last "lighted number" is played the CD stops. seem i have only half of the stuff ! lol !! have you ever experienced this kind of problem, i really love to fix it by myself Smile Any suggestion ?
  • 11-09-2010 3:31 PM In reply to
    • jl13
    • Not Ranked
    • Posts 8
    Problem solved . Just in case somebody else get the same, it was the big blue capacitor on the pcb 31 which was "on one leg". a little bit of solder and waou!! all is ok now. I even get a new one and change it for good.
  • 11-09-2010 3:51 PM In reply to
    OK, seems to have been an unstable power supply problem then... good work, and thanks for posting the solution Smile
    -mika
  • 11-10-2010 4:49 AM In reply to
    • Stonk
    • Top 50 Contributor
    • Joined on 04-16-2007
    • Marlow, Bucks, UK
    • Posts 1,688
    tournedos:
    Yes, thank youYes -  thumbs up
    If you think nobody cares, try missing a couple of payments.
