Latest post 10-17-2010 3:08 AM by hagan. 13 replies.
Page 1 of 1 (14 items)
  • 10-15-2010 11:28 AM
    Motorized Stand for Beovision MX 7000 - How to Programm Position?
    I got a Beovision MX 7000 whith Motorstand, really nice. The stand works and can change position by remote Beo4.
    But after starting TV it turns in the wrong direction. I did not match to change the programmed position. The main menue oft "TV" does not show a stand socket.
    Does anybody know how to manage? It is such a beautiful TV, it should work in the right way.
  • 10-15-2010 12:15 PM In reply to
    Re: Motorized Stand for Beovision MX 7000 - How to Programm Position?
    Using BEO4 remote: to preset an ON position yourself:
    MENU, then down arrow to SETUP.  Press GO  In setup menu, downarrow to STAND and press GO.
    Use the << or >> arrows on the remote until the TV is in the right position.  Press GO to store it.  Press EXIT to come out of the menus.  Or, you can use the 1 through to 9 numbers (1 is utmost left, 9 is utmost right).
    Dave.
    Am I ready? I was born ready!
  • 10-15-2010 1:02 PM In reply to
    Using Beo4 I press "menue" in TV mode: it shows me "program list" and "setup". Than with "go" on "setup" it shows me "Timer Sound on/off" "Power link on/off" "AV1:" "AV2:" "S-VHS on/OFF", I don´t find "stand"
  • 10-15-2010 4:35 PM In reply to
    Sounds like you're reading the BEO4 remote screen.  You do all of this with the TV switched on and all of the lists etc are on the TV screen, not on the remote.  Sorry, I should have been more clear.
    Dave.
  • 10-15-2010 4:45 PM In reply to
    No, sorry, this is what I read on the TV screen of the Beovision MX 7000.
  • 10-15-2010 5:04 PM In reply to
    • stotty1111
    • Top 75 Contributor
    • Joined on 12-16-2007
    • UK / France - Nth Worcestershire/Finistere
    • Posts 924
    • Gold Member
    Could be an early model, for use with a beolink 1000 the stand control on that is on the colour button , first item on list, use sideways arrows to position then press store button - think thats the system cannot remember but I have an early 7000 with which i can try the above tomorrow, the sets elsewhere you see
    hope this helps, of course it means you need a bl1000 handset unless someone else can outline this with a beo4
    tony
    I always try to operate using/following the KISS principle --  Keep it simple stupid!
  • 10-15-2010 5:26 PM In reply to
    It is a 93 Model
  • 10-16-2010 2:36 AM In reply to
    • stotty1111
    • Posts 924
    • Gold Member
    Have you tried pressing the list button on the beo 4 if stand is listed then press go and the sidearrows, until your position is found then scroll the list key to find store(?)and press go think that should do it, but maybe another member could confirm as i am not too sure beo 4 wise!
  • 10-16-2010 3:30 AM In reply to
    • Stonk
    • Top 50 Contributor
    • Joined on 04-16-2007
    • Marlow, Bucks, UK
    • Posts 1,688
    Have a look at THIS thread. This chap seemed to have sussed it.Smile
    If you think nobody cares, try missing a couple of payments.
  • 10-16-2010 3:31 AM In reply to
    Finding the right position works, but then the list key only shows "speaker" "clock" "return" "v.setup" "v.tape 2" "a.aux", don´t find any "store"
  • 10-16-2010 3:55 AM In reply to
    Well, it´s done, fantastic, thank you very much Big Smile
    TV-Mode, with "List" to "V.Setup", with "List" to "Picture", than "Go", in the left corner of the sreen appears "Stand". With "<<" and ">>" in the right position, than with "List" to "Store" and "Go".
    Really fineBig Smile
  • 10-16-2010 6:55 AM In reply to
    • Stonk
    • Marlow, Bucks, UK
    • Posts 1,688
    Yes -  thumbs up
    Glad you got it sorted. It shows how helpful a thread can be when the problem's been resolved and the OP concludes the thread confirming so. I wish more would do it!
  • 10-16-2010 6:59 AM In reply to
    Great news that it's fixed - well done one and all!
    Seems an odd way of getting to there though.  The earlier posted method is copied from the MX user manual and worked on mine in the past.
    Dave.
  • 10-17-2010 3:08 AM In reply to
    If you have a Beolink 1000 remote you just press: picture  << >> store.
