Latest post 10-18-2010 5:39 AM by stefan. 4 replies.
Page 1 of 1 (5 items)
  • 10-14-2010 10:24 PM
    How do I get the last but obsolete BM7000 software release?
    I have a Beomaster 7000 with software V1.0. This is coupled to an Avant TV through a beolink passive - 1612 with software V1.3.
    The last software release for the 7000 is V1.3 and of course is long obsolete. Does anyone know how I could obtain this last release - Part number 8342830 or even V1.2, part number 8341776?
    I have a 5500 too, with software that doesn't work with a 1612. It would be good to find how to upgrade the software here too.
    Thanks for any help!
  • 10-15-2010 1:56 AM In reply to
    Re: How do I get the last but obsolete BM7000 software release?
    Unfortunately it is not quite as simple. Although it is called software, it is in fact a replacable chip. You are also correct that this is now deleted from the B&O list of available software. One of our members did buy a job lot of software chips some time ago though I am not sure ezactly what it comprised.
  • 10-15-2010 5:30 AM In reply to
    • stefan
    • Top 50 Contributor
    • Joined on 04-16-2007
    • 200 miles from Struer
    • Posts 1,733
    Maybe it`s worth to contact Ulf. He is a Beoworld member in Germany and you will find him mainly in the german forum. Good luck.
    http://www.ulf-kiener.de
    Stefan
  • 10-17-2010 8:58 PM In reply to
    Thanks Stefan, Ulf was very helpful and the issue is now solved.
  • 10-18-2010 5:39 AM In reply to
    • stefan
    • Posts 1,733
    Glad to hear that you and Ulf could sortet it out.
    Stefan
