Hi Guys
In the above set up I have a Beovison 3 32", which has just had the software upgraded to sw10?, this was so we could control the Sky Plus Box, which works fine, i have connected a Beomedia 1 and I can see it upstairs on the mac, tranfer the music no problem, however I can not control it via beo4, I'm sure the command is vaux,(checked in service menu) but no control, it is connected via the ml, if I use the keyboard, it will work, reading the forum, I'm guessing it nedds at least Software SW15??, as this had the pc command. I'm I correct in this?? or should I be able to to use the vaux command with the software level I have (sw10??)
Regards
Paul
