I've just brought my Beogram 8000 out of storage so haven't used it for a while.
When I turn it on the sensor bar (the one beside the tone arm) flashes its little light every 5 seconds or so.
The table doesn't spin or the arm move.
Any ideas?
Update - if I unplug from the mains and then plug in again it does appear correctly with a red dot in the led. If I press TURN the turnable does spin but then no longer operates and reverts back to the occasional flash from the senor arm and I notice a flash of the LED and a slight attempt to turn the platter (barely noticeable)
Angus
