Latest post 10-11-2010 12:50 PM by Bv7Mk3. 4 replies.
Page 1 of 1 (5 items)
  • 10-10-2010 3:58 PM
    Advice regarding 7-32 or 7-40
    We're currently considering buying a 7-32 or 7-40. Are these to equally equipped in terms of hardware? Beosystem 3 etc?
    Thanks for your advice
  • 10-10-2010 4:25 PM In reply to
    Re: Advice regarding 7-32 or 7-40
    The newest Bv 7-32 has 2 hdmi sockets and NO Bs3 in it and  the older ones have no hdmi and only 1 Dvi (dvi does not carry sound).
    THe Bv 7-40 Mk 3 has 4hdmi's that you can use but the back the MK4/5 only has two Hdmi's as one is taken up with the Blue ray player (if fitted) and/or the Dvb tuner.If only the tv  has the Dvb tuner fitted then you have 3 hdmi's as no blue ray,which you can get/leave as  an option!
    Hope this helps.
    Bv7-55 & Bv7-32...Blue,lab1's x4,Yes4Blue, 6000x4Blue,Beocom6000 Blue,Beo5.Oh what a Blue set-up & a Beosound 5...After all,its Bang&Olufsen!
  • 10-11-2010 3:23 AM In reply to
    • hotknife
    • Top 150 Contributor
    • Joined on 02-03-2008
    • Solingen/Germany
    • Posts 552
    Regarding components the 7-32 is at least 1 year behind the 7-40. If you have the space and the money there is not a single doubt to go for the 7-40 (with 7-1/7-2 speaker).
    BeoVision 8-40, ATV2, BeoSound 4, Front BeoLab 9, Rear Beolab 4000 MKII, Beo 4
  • 10-11-2010 7:15 AM In reply to
    I was looking at the same two - except in my case a used 7-40 vs a new 7-32. Our Lounge isn't huge so we didn't want a domineering tv. We got a used mk3 bv7-40 on a low stand with the 7.1 speaker. It really does diminish the impact of the size. Also very happy with the picture quality and hdmi & blue ray options. A great tv !!
  • 10-11-2010 12:50 PM In reply to
    Glad you happy with the picture of your Mk3,I used to have one and had no problems with it and would recomend as the used tv to buy with Bs3 enjoy
     I now have a 7-55.
