j0hnbarker:Otherwise, you'll have to drag and drop files from your iTunes library into a relevant folder on your BS2. This is a bit lame though, as it treats all songs as one massive playlist, and you lose the album skip functionality (which is why I'm still using the old iTunes!).
There is nothing to stop you from creating multiple folders at the highest/root level.
Call them F1, F2, ... or FolderA, FolderB, ... or John Denver, The Eagles, ... whatever.
Then drop the assorted songs where you want them.
The BS2 should then calculate and construct the playlists for you.
First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
