Hello Keith,
thank you very much for the IR-Codes + Buttons - I already programmed my Beo 5, tested it and now it seems to work just fine.
Hopefully my Beovision 7-32 will get updated next week - then I can use it with my Apple TV in all it's glory :-)
I had one issue with the config tool: when I changed the color of the buttons, I lost the IR-Code for this specific button after leaving the menu of this button. Is this a bug or a feature?
btw: for me it works just fine without the PUC-Codes - mainly because I fixed the ATV II directly under the BV 7-32 - so it gets always the IR-Signals and it is very unobstrusive (almost invisible). When the installation is finished (need to solder some wires) I will post some photos.
