1st March February 2012
Latest post 05-06-2011 1:05 PM by Razlaw. 21 replies.
10-09-2010 4:51 AM
bayerische
- Joined on 12-11-2007
- Helsinki, Finland
- Posts 3,593
Hi guys,
A quick question, I've just learned what DVB box I need to use with the BV10 to get the STB controller to work, but what about Blue-ray? Can the BV10 control Blue-ray players?
Andreas
-Andreas
BLab5, BLab5000, BLab8000, BV10, BS9000, BS3, Beo5, Beo4, BLink1000, BLink5000, BLink7000, A2, A8, Form2
steph
- Joined on 04-16-2007
- France
- Posts 612
Yes,
the PUC can be loaded with some blu-ray models.
I personnaly use a panasonic blu-ray and it works like a charm (very fast, no pana logo...).
bayerische
- Helsinki, Finland
- Posts 3,593
Thanks,
is the PUC list available somewhere?
Do you know a specific Panasonic blue-ray that works?
-Andreas
TripEnglish
- Joined on 10-27-2007
- America
- Posts 1,595
The PUC list is pretty big at this point and I don't know if it being published in print anywhere, but your dealer can certainly confirm the support for any device.
The good thing about Blu-Ray players is that they tend to recycle remote codes within brands. So Sony, Panasonic, Pioneer, Samsung etc. are all generic codes that operate any blu-ray player.
Same goes for media servers, and other types of set top boxes.
There is scarcely anything in this world that some man cannot make a little worse and sell a little more cheaply. The person who buys on price alone is this man's lawful prey. - John Ruskin
bayerische
- Helsinki, Finland
- Posts 3,593
TripEnglish:
Thanks Trip,
Could anyone give me a good tip on which Blu-ray player to buy?
-Andreas
bayerische
- Helsinki, Finland
- Posts 3,593
Just found a very cool BR player... Wall mountable.
The Samsung BD-C7500, not B&O, but pretty cool.
Will this one work?
-Andreas
BEOKNOW
- Joined on 09-11-2008
- Posts 59
There are two very slim Samsung Blu-Ray players that are very well suited to BeoVision 10, and are controllable with Beo4 & 5 via the PUC table. In addition, STBbrackets make mounting solutions to allow the player to be located “out of sight”, on the rear of the BeoVision 10 (and other BeoVision models).
It really is a very smart solution. Maybe visit http://www.stbbrackets.co.uk/?page=prodlist&catID=37
For those of you who want to have some fun configuring your BluRay player (or any other device) onto your BeoVision, play with this on line configuration tool…………………………. http://www.stbbrackets.co.uk/?page=configurator This is how the dealers select the correct bracket configuration and advise you on what can be added to your TV when you buy.
I have also seen STB’s latest configuration tool which they demonstrated to some acclaim at the dealer conference in Aarhus…..wow that will be something when it is launched in the spring………..I’ll post details later
misled
- Joined on 04-25-2007
- Switzerland
- Posts 66
hi
i have the samsung bd-c7500 connected to my bv10-46 with puc.
the only problem is the up/down and left/button don't works! (the installation have make my dealer).
any ideas for this problem?
tanx
BVision10-46,BLab11,BSound5,BMaster5,BLab8000,BLab6000,BLab2500,BCom5,BCom6000,BeoTime,BeoPort,Beo4,Beo5
DoubleU
- Joined on 05-09-2007
- Posts 866
Are you using the "old" Beo4?
Navigation button is probarly "on". Navigation button is used for the new Beo4.
misled
- Switzerland
- Posts 66
yes, i have a old beo4.
you think i must have the new one with the new navigation button
sergi0
- Joined on 03-06-2011
- Posts 99
Hi Koning,
I completely agree with you. This mediaplayer is simply the best in term of ability to read any format, display subtitles... It just need to be hidden (it is not very design... ;) and lack from a nice interface.
sergio
Razlaw
- Joined on 04-24-2007
- Illinois
- Posts 1,770
The Samsung pictured looked very nice to me. Thought I would read some about it and came across this Samsung........
http://www.samsung.com/us/video/blu-ray-dvd/BD-D7500/ZA
Beosound 1, 5, 2000, and 3000
Beotime, Beotalk, Beocoms
beoaus
- Melbourne, Australia
- Posts 445
TripEnglish:
Rant....
I do find asking a dealer or service for which boxes can be controlled by a STB akin to pulling teeth. Maybe its my approach...
Beoaus.
Rant over.
misled
- Switzerland
- Posts 66
the new PUC works only with the new beo4!
i bought the new one and voilà it works!!!
misled
- Switzerland
- Posts 66
go and up or go and down don't works!
realy only with the new one
Razlaw
- Illinois
- Posts 1,770
I purchased the Samsung BD-D7500. Very pretty, matches B and O very well. Unfortunately, it does not work and will be returned. I connected it by HDMI and set it to output PCM to my BV7-55. If I put a disc in with uncompressed 7.1 PCM, all worked beautifully. However, if I put a DolbyTrueHD or DTSHD disc in, the player decoded the track and then downconverted it to 2.0.
I called Samsung support, I was then connected to "Tier 2" support. After a lengthy discussion with them, they confirmed that there was a problem. They elevated it again to some higher level of tech support and gave me a reference number. I was told they would call me back. They never did. When I contacted them to follow up I was told that they had no record of any incident matching the reference number they gave me.
It matches B and O so well it is really a shame that it does not work.
Page 1 of 1 (22 items)
