Latest post 11-04-2010 3:46 PM by elephant. 4 replies.
Page 1 of 1 (5 items)
  • 10-05-2010 9:18 AM
    Reinstalling AppleTV
    Hi
    I'm reinstalling my system after a house move and am struggling with the AppleTV.
    There appears to be a fault with the 'Apple Remote' control software as only a few of the keys on the Beo4 produce any activity on the ATV, and even then it's the wrong action.  E.g. 'Stop' works as 'Enter', Up/Dn arrows don't work at all.  The AppleTv works fine with an apple remote and the PUC cable etc works fine when I switch it the Sky box.
    Do I have to use a specific PUC output (I can't remember which was used previously) but I'm now connected to 4?
    Is it possible that the software has somehow become corrupted?
    Thanks in advance.
    AP
  • 10-28-2010 2:39 PM In reply to
    Re: Reinstalling AppleTV
    You need to de-connect the original apple remote. Then the BEO4 works well.
    BeoVision 8-40 / BeoVision 8-32 / Beovision 6-26 / BeoSound 3200 / BeoSound 1 / BeoLab 3 /  Beolab 6000 / Beolab 2000 / Beoport / Beomedia 1 / 3* Beo4 /BeoCom 5 with VOIP
  • 10-29-2010 5:51 PM In reply to
    Heribert:
    How does one "deconnect" ?
    Are you talking about pairing ? or de-pairing ?
    First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
  • 11-04-2010 2:44 PM In reply to
    Heribert:
    Thanks for the information - I'm not exactly sure what you mean - if you could clarify then I'd be grateful.  In the meantime I'll have a play with the remote control settings on the ATV.
    AP
  • 11-04-2010 3:46 PM In reply to
    Pestria:
    Heribert:
    AP
    What I did on my Apple TV was (using the apple remote) scroll to the "configuration settings" on the right and then scroll down to the "remote" option and then select "unpair", this opens up the Apple TV to processing IR signals set from any remote which includes the PUC emulating an Apple
